Page 55 of 56 FirstFirst ... 54550515253545556 LastLast
Results 811 to 825 of 826
  1. #811
    Sep 2018
    Hello, which Programmer you guys using for Xicor x28c64-jm-20
    I have N14 Cellect Plus with faulty code 111. We reprogram the ECM with a Insite 8.7 and faulty code gone for a 10 days and today is back.
    I was reading that need to change the Xicor x28c64-jm-20 but after changing the ECM wont program with Insite and i believe that the IC must program before solder.
    PLS any help will be appreciate
    Thank you !
  2. #812
    Sep 2018
    Quote Originally Posted by maax990 View Post
    Hi I need your help
    Ecu 2350B
    Insite error code 5080
    ID from Calterm:
    Device Address 0x00
    Product ID: ABC,BDC
    Part Number:5317110
    Serial Number:5203034
    ECM ID:G2
    I only have an ECU with only one sticker on it , is it possible to somehow find out what is to be uploaded there ??? maybe someone has such a file for calterm???
    I can only upload it on the bench or JTAG(Trasdata)
    Attachment 892008Attachment 892009Attachment 892010
    What you can do for cummins you just need a part number and Engine Serial number and you can see which Software calibration you need to install.
    Please provide a Engine SN.
    I have seen ECM that are calibrate with a wrong Software because people some time buy and install without programming.
  3. #813
    Apr 2023
    Hi to everyone.
    Celect plus emc and fault code 441, Low battery level. Bat voltage measurement singnal goes correctly thru the multiplexer circuit.
    What could cause this fault inside ecm?
  4. #814
    Top Poster + donniemnemonic's Avatar
    Nov 2010
    Hell's garden of eden.
    This thread needs reviving. After years of working on these knowledge sharing is not a bad thing. Will not spoon feed anyone but will nudge you in the right direction. Best way to learn is by experimentation.
    Donniemnemonic...
  5. #815
    Sep 2018
    Hello, i have N14 celect that has a BAD EEPROMS is there some one that can upload the HEX or BIN from a EEPROMS 2864?
    I try to calibrate with new ICs but stop on 65% and if somebody can give me an Idea i will appreciate!
    Thank you !
  6. #816
    Sep 2018
    Im agree with you donniemnemonic!
    After so many years we need to refresh the topic and i hope there will be more people agree with you.
    Im going to be here and help with my experience as a electronic technician.
    Who is agree to refresh the theme and start helping each others ?
  7. #817
    Oct 2015
    Available
    CAT ADEM III internal circuit diagram
    CAT ADEM 4 70/120 pin internal circuit diagram
    CAT ADEM 4 64/64 pin (C6.6 C6.4) internal circuit diagram
  8. #818
    Sep 2018
    Default price
    Quote Originally Posted by linux2010 View Post
    Available
    What is the price ?
  9. #819
    Oct 2015
    Quote Originally Posted by mmfix View Post
    What is the price ?
    CAT ADEM III internal circuit diagram--- 100 USD
    CAT ADEM 4 70/120 pin internal circuit diagram ----- 250 USD
    CAT ADEM 4 64/64 pin (C6.6 C6.4) internal circuit diagram----- 250 USD
  10. #820
    Sep 2018
    Question Guys i have a bad Cummins Cellect pand ECM and water goes inside i clean fixed but the timing chip SC408069FMFN is bad and ECM wont connect to PC I replace it from another board but still not connect to the PC but now consume normal Amps.
    My question is is the SC408069FMFN need to be program or not?
    Thanks !
  11. #821
    Nov 2010
    Thank you !
    HI m8
    Did you ever get this resolved. Was offline but just seeing your message now.
  12. #822
    Nov 2010
    Thank you !
    HI m8
  13. #823
    Nov 2010
    Thanks !
    Hi m8
    Did you ever get this resolved?
  14. #824
    Sep 2018
    Hello donniemnemonic, sorry for the late answer but i see the thread is almost dead and no one repair or share any more information. I didnt expect to answer me.
    Also im not sure how to make the forum notification on treads the someone answer me.
    Yes i did fix that ECM I contact with some of the members on direct message unfortunately no one had exact what im looking but i got a luck and i got the same part number ECM for repair and i was able to take the Bin flash files from it and fix the my other unit . I would say will be very good if we make a closed good community for ECM repair. I do repair phone and the community is very very powerful out there even FB pages and Wiki. If you want to contact faster with me just use PM-personal message
  15. #825
    Jun 2024
    Hello, I came across this thread and would like to mention that Weller Truck Parts in Grand Rapids Michigan is the industry leader in repair and remanufacture of the Celect and Celect Plus ECM. We have developed replacement circuit boards and hardware. I am the guy who created the program in 2009 and still manage it to this day.
    Code 111 is often one of the three EEPROM, either the X28C64 or 28F512, but not always, it can also be from failing RAM and the proprietary QFP100 processor. Best bet, and standard practice for us is to replace all those chips. Another culprit can be not the ECM but either a non-stable battery supply or an ignition circuit that is intermittent. When the ignition is turned off, the EEPROM is updated with drive cycle data, if supply of VIGN fluctuates, it can interrupt the write and cause 111 or a ROM-Boot, or a "brick". We see this all the time with the fleet aging. Code 111, if set to inactive, will usually return within 150 hours of operation.
  16. The Following User Says Thank You to Ryanvv355 For This Useful Post:
    mmfix (18th June, 2024)
