Page 11 of 38 FirstFirst ... 67891011121314151621 ... LastLast
Results 151 to 165 of 569
  1. #151
    Quote Originally Posted by valli View Post
    From where i can buy this tool kit ( and please give me a part number if you have ) ?
    211 589 04 21 00 = 211 589 04 21 02 + 211 589 04 21 03 + 211 589 04 21 05 + 211 589 03 21 03
    I don't know actual price...
    BR
  2. #152
    workshop
    you can working with this tool only with original
    compact3,or4
  3. #153
    Default Developer mode and speed limit at the cars
    Hi m8s!
    Actually who know just answer @Yes@ or "No" about speed restrictions, for 211 E55 AMG Kompressor, 220 s65 AMG Biturbo?
    Every day, every hour I like. Still alive.
  4. #154
    Hi Everyone,
    I would like to know how to increase wiper speed when the knob is put on the max. I find that MAX is not fast enough. My Acura MDX has faster wiper speed than my E-Class.
  5. #155
    DK Veteran Mackhack's Avatar
    I looked into that before too and I couldn't find it. I believe that this is nothing that can be changed via SDS. I keep looking though and will post if nobody else posts in the meantime.
  6. #156
    "Wischerfunktionalit?t" under Driver SAM. Inside it, I see Byte 02 to 05 with a list of secs can be chosen. 2s to 7.5s. Probably that is not what I am looking for.
  7. #157
    Quote Originally Posted by crazypotato View Post
    I'm German so I can tell you that you might found the correct spot. "Wischerfunktionalit?t" means Wiper functionality at a 1:1 translation.
    Have you changed something there already?
  8. #158
    I made a screenshot of the menu. See if anyone can decipher it. No, I haven't changed anything yet. I am doing it on DAS Sim. It is cold outside in where I live. I will find a better day to work on my E.
  9. #159
    "Intervallzeit" means Intervall time. And if they are all set to 2 seconds something might be wrong b/c the faster the wipers move the shorter the intervall time should be. Oh wait, it's DAS SIM. Never mind. You're on your way I think.
  10. #160
    the options in the drop down list are 2 sec, 5 sec, 7 sec and 7.5 sec.
  11. #161
    Is it possible to change tacho scale in W221 instrument cluster?
    I can see with dev data the possibility to change it to 320Km/h or 360Km/h, but after reset instrument cluster it remains the same 260Km/h.
  12. #162
    I done that on some W221 without problems...
    Quote Originally Posted by papalos_ View Post
  13. #163
    Quote Originally Posted by forestml View Post
    Can you describe the steps to do that?
  14. #164
    Noting special at all, but I think you have to change this value in 3-4 submenu in IC, not only in one menu. Then of cource ECU reset...
  15. #165
    Do you remember the other submenu in IC I need to change? I've try a lot of combinations without luck!
