Page 25 of 38 FirstFirst ... 15202122232425262728293035 ... LastLast
Results 361 to 375 of 569
  1. #361
    Quote Originally Posted by Tex5 View Post
    I have read this all thread I am still not sure to know the answer to my question.
    I onw a W209 CLK 55 AMG with speed limit at 250KM/h. I would like to remove or upgrade it (to 300km/h?)
    Is it possible with DAS (w/wout Dev mode), need to have ECU file with 300/no limit, or just change a parameter to ths ECU (how ?) ?
    It seems to be different from year of production 2006- and 2006 +
    Thanks a lot
    Hi m8 !
    Did you solve ? If Yes, tell me please - how )))
    Every day, every hour I like. Still alive.
  2. #362
    Jul 2012
    What a waste of internet, 25 pages of nothing. Internet is not what it use to be. O people?
  3. #363
    smayer's Avatar
    Jan 2012
    Quote Originally Posted by johnshmit View Post
    i agree, All post like yours is a waste of Internet.
  4. #364
    DK Veteran Mackhack's Avatar
    Is it possible to disable the peep and CI message to close the sunroof? Haven't found it in over 4 years of actively working with developer.
    That would be sweet.
  5. #365
    Jun 2012
    Quote Originally Posted by CarmasterAndrew View Post
    Hi m8 !
    I have not yet try
    I need to find time to do it with my friend C3
    But in Das sim I think I have found the way to do it
  6. #366
    Mar 2009
    hi!
    I had problem with W211 SBC, it has "power on reset" or similar dtc , becouse battery was flat ,cannot erase this dtc normally.
    dtc erased with developer, but sbc lost SBC HOLD function.
    How to activate back SBC HOLD ?
    regards
    Tod
  7. #367
    Mar 2012
    I have a problem with a 2011 w204 benzin engine.
    car has caught on fire, so my customer replace engine, ECM and ESP control unit. I virginized ECM, adapt with STAR no problem, but for ESP, it don't want to adapt as there is an other VIN in module (used unit). is there a way to adapt to vehicle (without SCN coding if possible) if I don't have access to old unit (it is totally burn).
    in other word, is there a way to make ESP unit virgin with developper function?
    many thanks!
  8. #368
    Prussia
    I think its a new unit you need
  9. #369
    Mar 2012
    Quote Originally Posted by TULGEYWOODMAN View Post
    yeah, this I know... but I am looking around to check if there is some "other" solutions!
    I would like to be able to re-adapt used ESP unit! if my only problem is SCN coding, we are able to find solution. but for now, my main problem is about VIN in unit.
    so looking for a way to virginise unit or change VIN at least!
    I'll play around with SIM DAS... we will see what we'll found!
    if someone else has experience with that, I'll be more than happy to receive some more advice! if someone knows what kind of MCU is in that ESP, it would also help!!
    regards
  10. #370
    Prussia
    The problem is the way the vin is written.
    I have an software engineer working on this.
  11. The Following User Says Thank You to TULGEYWOODMAN For This Useful Post:
    mcab (13th August, 2019)
  12. #371
    Birmingham
    Default How to add Cruice control to Vito - 08 onwards
    How to add Cruise control to Vito after 2008..WITH Developer tested with 01/2011 DAS
    Log into vehicle.
    Select ESP
    Go to Control unit adaptations
    Select Cruise control
    select Cruise Contol ON - Or with Winter tyre limiter
    click F3 then F3 again.
    Coding complete
    If you don't have the cruise control option in that screen then -
    Log into ESP
    Go to Development data
    select Control unit adaptations (Variant coding)
    Click on Laengsregler Kodierung
    select Tempomat Ein or Tempomat und Limiter ein
    Click F3 and F3 again - Coding complete
    To check that it is on in IC start vehicle and press the limiter in on the stalk and see if the limiter display shows on the instrument cluster ( in KM usually) in the middle display.
    If not - Can message is not set to see cruise from ESP. you need to set the IC.
    Log into IC
    Go into Development data
    Go to Control unit adaptations (Variant Coding)
    Select Variantenkodierung
    See Line that says - Limiter tempomat signalquelle <It should say NOT VIA CAN ESP MESSAGE
    If it says ESP CAN MESSAGE then look at other units.>
    Select ESP CAN MESSAGE
    Click F3 then F3 again then F2
    Coding is done.
    Check Also in ECU coding to make sure that it is on.
    Log Into vehicle
    Log into ECU
    Select control unit adaptations
    Read coding and change if necessary
    If it tell you it has Cruise control - then exit
    If not scroll down the list and turn it on - Like - Manual Transmission-cruise control-Air conditioning <EXAMPLE
    Then F3 and F3 again then it is set.
    To test with STAR - Log into EZS and iun actual values see Cruise control and move the stalk to see if it works properly!
    After all of this if it doesn't work check Clutch pedal switch and brake switch for good contacts!
    Hope this helps!
    Mark
  13. The Following User Says Thank You to MarkPRP For This Useful Post:
    Techhead (13th April, 2013)
  14. #372
    omglol's Avatar
    Jan 2009
    Europe
    I need a little help. I've read a lot of threads here on DK, but I can't find specific answer/instructions.
    How exactly do I disable passanger seat occupancy sensor on Mercedes C-class (W203), make year 2004? Thanks!
  15. #373
    Are you talking about WSS (Weigh Sensing System)? I know MB uses 2 different methods (WSS is being used in the US).
  16. #374
    workshop
    Quote Originally Posted by omglol View Post
    dev-mode
    coding-anpassungen
    no akse
    and unlock signal wire
  17. The Following User Says Thank You to mercis For This Useful Post:
    smokey08 (14th February, 2014)
  18. #375
    omglol's Avatar
    Jan 2009
    Europe
    By "unlock signal wire" you mean disconnect signal wire?
