Page 27 of 38 FirstFirst ... 17222324252627282930313237 ... LastLast
Results 391 to 405 of 569
  1. #391
    Originally Posted by james44000
    Is it possible possible to change vin in automatic transmission and motor ecu with dev mode?
    what is the model and year?
    It's for sprinter 2009 cdi
  2. #392
    Quote Originally Posted by james44000 View Post
    Not always NANTES. But Hex bin will help.
  3. #393
    Aug 2012
    Quote Originally Posted by ricardyfer View Post
    hi Sr. Qirus and all members.
    Is it possible to deactivate DPF filter in developer mode?
    Thanks...
    Yes you can-in Bulgaria
  4. #394
    Birmingham
    Sprinter w906 limiter removal.
    1 - In Dev mode go to Control unit adaptations
    2 - select menu HGB
    3 - see drop down list of speeds
    4 - select desired amount and press F3 and then yes.
    5 - go back to normal mode and into control unit adaptations and maximum vehicle speed.
    6 - see new value and go get some speeding fines!
    Mark
  5. The Following User Says Thank You to MarkPRP For This Useful Post:
    scoot (30th March, 2015)
  6. #395
    But with obd you save time
  7. #396
    Jun 2012
    Quote Originally Posted by Mackhack View Post
    You need developer kit access and change the Vmax to 300 km/h. That's it.
    Hello
    I bought a SD Connect C4 and installed Xentry 09.2012 with a dev key (given by this forum )
    I tried to find how to remove/upgrade the speed limit.
    I only found this in dev variant coding :
    But there is no value above 250km/h which is the speed limit I want to up. Any idea ?
    Best regards
  8. #397
    DK Veteran Mackhack's Avatar
    Only AMG vehicles can have Vmax = 300 km/h with developer mode.
    Anything else needs a special file generated by AMG/Mercedes sent to your authorized dealership for version coding. And that dealership has to be a dealership, not a mom and pop shop. MB/AMG will not send it to just anyone.
  9. #398
    Jun 2012
    Ok but I have an AMG vehicule, it's a 2003 W209 CLK 55 AMG
    Perhaps only for more recent AMG
  10. #399
    Nope. Should work. Try an older version perhaps. I'm working on cars with 10/2008 b/c it has many useful features on it that newer versions don't have anymore. And yes i did code AMG vehicles to 300 km/h before.
  11. #400
    Jun 2012
    Thanks, you think it is du to DAS version ?
    I think I will ask a friend with an older DAS version because the installation of 09.2012 was very long and I have not for the moment the courage to install another version
  12. #401
    Possible, since I don't have the problem.
  13. #402
    Hi there! Not agree, coz 300 km /h limit is only avaliable at the S-class CL-class and M 164 only if all these cars are natural AMG born )). 211, 209 cars haven't 300 km/ h in the developer menu. Also w220 with 275 biturbo 6.5 l motors haven't above string (300 km/h) BR
    Every day, every hour I like. Still alive.
  14. #403
    Quote Originally Posted by CarmasterAndrew View Post
    B/S! I wouldn't tell him that if I haven't done so. I coded several E55 AMG here in the US as well as on trips to Europe before (RoW cars) to 300 km/h with my 10/2008 Developer-Kit SDS. Check your facts before you post this crap. All NONE-AMG vehicles cannot be coded to 300 km/h (at least with DAS/Xentry). There comes this data file in place which becomes generated by AMG for AMG and NONE-AMG vehicles alike which contains some sort of firmware which opens the governor to 300/320 and 350 km/h. And cars that supposedly go even faster have it set to a speed that is much higher than the car can go due to roll/surface/wind resistance (<400 km/h).
  15. #404
    Easy , easy m8 !
    B/S probably your breakfast! I mean that by means of just SDS .Be cool m8!
  16. #405
    Easy , easy m8 !
    Good one Still true what I wrote about AMG/None-AMG vehicles.
