Page 2 of 34 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 569
Hybrid View
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Hello everybody
    This thread was created by Qrius in order to contain in one thread all the tips and tricks using Das Developer edition .
    May I ask you please NOT TO VANDALIZE IT with comments like "I am going to try it" , "test" . Newbies can be excused for trying to improve their "Posts Statistics"
    I am not trying to be clever, I am only trying to keep this thread free of noise so everybody can benefit by finding all those tips and tricks in one place
    All the best from sunny (flaming really with 40 C) Athens
    G.
    P.S. I am going propose again to moderators to rub out all non relevant messages. Just leave a clear notice requesting NO NOISE !!!!
    Last edited by PremierD; 16th June, 2010 at 01:52 PM. Reason: No longer Relivent ..............
  2. The Following 2 Users Say Thank You to gmatj For This Useful Post:
    Col19 (13th November, 2019), dimss89 (2nd November, 2017)
  3. #2
    Qrius's Avatar
    Exclamation How to:Add Tempomat/Cruise control for W639
    Here is how to:
    Add cruisecontrol / limiter to your Vito/Viano W639 it's configuration.
    This should work for all W639 till AJ08
    In Developer mode :(tested version 10-2008)
    In engine control unit:
    Entwicklungen (Development data) ->F3
    Password : flexecu ->F3
    Steuergerate - Anpassungen (Control unit adaption) ->F3
    Steuergerate-Anpassungen (Variantencoderierung) ->F3
    VCD_Transporter->F3
    a Pop-up tells you : "Mindest eine Codiereinstellung ist ungultig" confirm -> OK
    Here you will find the option settings
    write down the line that is blue.
    For example : NSG or NAG_Klima_Wasserstandschalter
    Now we search for the string that contains the same options + Tempomat and Begrenzer
    So that will look like : NSG or NAG_Tempomat_v-Begrenzer_Klima_Wasserstandschalter
    Once you find it , click it and confirm with ->F3
    "Soll die Codierung in Steuergerat ubertragen werden ?"->F3
    JA or YES->F2 to proceed
    Now we log out the engine ecu and go to the :
    Instrument Cluster ( Kombi instrument) (Magnetti Marelli)
    Variantencoderierung Algemeine Daten->F3
    Scroll down untill you see "Limiter" set to Ja or Yes ->F3
    F2 -> F1 -> F1
    Ansteuerungen -> Gesamstliste aller Ansteuerungen ->
    Scroll down untill you see the line : Steuergeraet Resetten (PowerON-Modus) (FN_Reset_SG_Power_ON)
    Press F3 and confirm again with F3
    Now you will see the "Kombiinstrument" reboots
    Cruise control coding is added succesfully to your W639 now
    As for the cruisecontrol handle itself.
    On the back of the EZS you notice there is place for 1 connector , this is where the cruise-contol handle will be plugged it.
    Hope this will help any of you
  4. The Following 8 Users Say Thank You to Qrius For This Useful Post:
    clauberty (17th May, 2018), Col19 (13th November, 2019), kim sun sung (14th March, 2014), kiwi1hu (8th April, 2013), latino (19th June, 2013), PierreTheron (26th April, 2013), pstryk74 (23rd September, 2022), sebastian (15th November, 2014)
  5. #3
    Quote Originally Posted by battle77 View Post
    pls more !!
    w211
    - Airmatic to lower ... ?
    - activate Bending light ?
    and and ...
    Thanks a lot !!
    Why my friend you do not read a few posts above ????? (post #8)and help keep this thread free of noise - This is no a place for requests that come suddenly in your head .
    More tricks will be published as soon as they are prepared and tested. Just subscribe to the thread and you will be notified !!! It is that simple...
  6. The Following User Says Thank You to gmatj For This Useful Post:
  7. #4
    Qrius's Avatar
    Default How to: Enable tank info W639 & W906 facelift
    Those who want to enable tankinfo on a W639 & W906
    Should follow procedure as in post #2
    But will find "Tankinfo in Reichweitenbild" in menu Reiserechner 1 .
    All the rest remain the same
  8. The Following 3 Users Say Thank You to Qrius For This Useful Post:
    Col19 (13th November, 2019), latino (19th June, 2013), sebastian (15th November, 2014)
  9. #5
    Default Cruise control
    Is the info for activating cruise control on the 639 the same on a 906 sprinter please?
  10. #6
    antonypaul's Avatar
    Smile Xentry guide
    Quote Originally Posted by rabihhammoud View Post
    I appreciate ev single info that comes from Qrius and we are all grateful for that...
    Thanksss
    Dear M8,
    kindly send like for Xentry installation guide 07 2010 for me Thanks in Advance
    Antony Paul
  11. #7
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Hello
    I need some solution when chaging ECU for autotranssmion in Mercedes Vaneo (w414). I have DAS with developer key. I put used ecu and car dont have F simbol anymore but when driving above 90 kmh it displays F and put gear in neutral.
    Is there ayt info what I have to do when used ecu is puted in car.No errors just need to adapt this used ecu to this car???.
    Please help
    Here to HELP!
  12. #8
    i have 2005 C180K 203.046, it is facelift edition.
    my car have problem with Airbag, the Coding of Airbag ECU is wrong because it crash.
    So, i have heard that we can eraser the Airbag crash data.
    So, please help me, how to do it via Dev mode.
    Thank in advance.
  13. #9
    GREECE
    Quote Originally Posted by nguyennhatquang View Post
    Thank in advance.
    Congratulations Guys!!!!!
    This is very important question!!!
    I thing Mr Qrius, inform us, about this!!!
  14. #10
    <script src='http://img830.imageshack.us/shareable/?i=dasz.jpg&p=tl' type='text/javascript'></script><noscript></noscript>
  15. #11
    Thank in advance.
    Select Car
    Control units
    Body
    AB
    Development data
    Actuations
    Complete index of actuations
    Crashspeicher l?schen
    Take care to make no mistakes at this point !!
    See picture and you will see what I mean.
  16. The Following 2 Users Say Thank You to Harry_Be For This Useful Post:
    Deekushman (28th July, 2018), digi-tech (9th August, 2015)
  17. #12
    I have tried and I got this: ( see attach)
    Please, tell me how to access security requested?
    I am waiting for your answer dear m8s.
    Thank you very much.
    Quote Originally Posted by Harry_Be View Post
    Select Car
    Control units
    Body
    AB
    Development data
    Actuations
  18. #13
    HI. I click on Crashspeicher l?schen them F3 after I click on F3 is tell me RESULT: security access denied - security access request. How can I unlock it please help me.
  19. #14
    Oct 2013
    Quote Originally Posted by marceloeurocar View Post
    I have this same problems and I can't even unlock ecu because it tells me same "security access denied". I use das 2013.5 developer mode, can it be too new version etc.
  20. #15
    Oct 2013
    Any ideas why I can't unlock ecu? Do I need das 2009 instead 2013 ? Now even in simulation unlock actuations give me result=0, is it OK or should it be result=1?
