Page 6 of 38 FirstFirst 123456789101116 ... LastLast
Results 76 to 90 of 569
  1. #76
    Default AB Eintrigeln
    I mean guys Airbag module for instance on 211 . Thanks for earlier reply ^-)
  2. #77
    DK Veteran trigital's Avatar
    Quote Originally Posted by Qrius View Post
    Oke , as for a solution to do the DPF regeneration manual in Developer mode.
    You can start the process with the line : Manuelle Partikelfilter Regeneration (FN_Manuelle_Partikelfilter_Regeneration)
    To stop the procedure : Manuelle Partikelfilter Regeneration Routine stoppen (FN_Manuelle_Partikelfilter_Regeneration_stoppen)
    In NO way do i support this procedure
    On many CDI's the Dev menu is missing or the actuation shows 'not suported' and if you need to start the regeneration from normal menu it ask for a password. Ex; wdd169006 CDIA1.
  3. #78
    Qrius's Avatar
    Quote Originally Posted by trigital View Post
    In this case i guess you should go back to a older version of DAS
  4. #79
    impactops's Avatar
    Quote Originally Posted by MR_SMITH View Post
    Yes , very dangerous risk of fire . Thank you.
    You can use this method to light your cigarette..
  5. #80
    But must take care, because the new version of DAS lock the ECU for regeneration and even with old version not work!
    I try with 05-2010 on my A-Klass and now 03-2010 ask pass.
  6. #81
    DK Veteran Mackhack's Avatar
    Why would someone need to do this with the filter?
  7. #82
    workshop
    change first "differencedruck sensor"
  8. #83
    It's all right there as described. I did it once at a friends car.
  9. #84
    Quote Originally Posted by Mackhack View Post
    Someone trying to burn out corroded metal inside of DPF so he don't want to pay 2000 euro for the dpf
  10. #85
    Hi, i'm considering, can we enable the tank info in Benz W204
    i can't find the line Tankinfo im Reichweitebild in Xentry Dev Mode.
    Thank you in advance.
  11. #86
    Is there Xentry Developer mode if you see same window like in DAS developer (Deutch language warning)?
  12. #87
    Qrius's Avatar
    Quote Originally Posted by simppa80 View Post
    Have a look here : http://www.digital-kaos.co.uk/forums...94/#post692873
  13. #88
    Quote Originally Posted by nguyennhatquang View Post
    There isn't "tank info" option in W204 mate. I was looking for that with DAS developer a lot of time ago.
  14. #89
    I have used that, but i'm asking do xentry show same windown like DAS?
  15. #90
    DK Veteran cocutanu's Avatar
    Jun 2009
    What Xentry will show you is this...
    Last edited by cocutanu; 7th August, 2010 at 11:57 PM. Reason: Sorry for the previous one !
