Is there anyway to enable "SBC hold" and "SBC Stop" in a 2005 W211?
Sensotronic Brake Control is serial equipment for W211, and by default, SBC Hold & SBC Stop are enabled by default. So, if they dont appear in IC, there has to be a message indicating a problem. Maybe it is a faulty gearshift lever module, which could have problem with ground. IMHO, repair isnt possible.
greetz
That is right. That feature was never in USA models.
If someone can show us how to enable Date on IC and Windows Auto Close when car lock, it will be very useful.
i follow this guild for W211 series..To be able to do such instruction you first need to unlock the ecu.
this should go with Steuergerat enriegeln (FN_SG_Entriegeln)
when your done adjusting code , you should lock the ecu again with ; Steuergerat verriegeln (FN_SG_Verriegeln)
Hope this helps !
but it keep say : security problem..so how can i fix it
i want my climate control alway Recirculate
before DAS 07.2009, i can use special setting..
but now, the key generator can't work..
but i have heard that, Dev mode cover all Special setting.
So please help me
Thank in advance
sorry, this *** u sent to me doesn't have key for special setting in DAS.
would u please try again.
but it is old W203 men..
it don't have this menu
it is 203.045..
