https://www.youtube.com/watch?v=3w0zDmxY1I0
AMG logo, red needle, timer etc under AMG menu
Hi 2009 e280 W211 UK
could any one let me know how to enable Speed or Temp in the status line? (Above trip distance)
Uk cars are locked to K/ph but you can change it so it reads temp?
Many thanks
In your IC settings. You don't even need a SD for that.
Greek God (14th June, 2014)
Cheers Mack but the UK car doesn't give that option in the Instrument Cluster settings.
Then make this menu visible with your SD.
My CLK W209 is with disabled seat belt warning, but I want to enabling this function. Can you help me? I tried dev. mode on instrument cluster following options:
1) Gurtwarnung display - change from passive to active - not this
2) Gurt Akustik - change from passive to active - not this
3) Gurt - change from passive to active - not this
4) Gurtwarnung ein - change from mit Motor to mit Kl15g - not this
5) Gurtwarnung abbrechbar - change from aus to ein - not this
I think that trying everythink. Thank you.
use 2 and make ecu reset
mbsupport (7th July, 2014)
I tried. You mean instrument cluster reset? When I enabled this function, when start the car I heart only 3 times gong.
There are more settings that need to be changed as explained in my PM to you.
I haven't PM. Please tell me which setting. Thank you.
P.S. Its done
