Results 1 to 7 of 7
    rtvservis's Avatar
    Default Sony CDX-M800 code help
    Sony CDX-M800 Code Help .!:
    bonus2010's Avatar
    Scotland
    Quote Originally Posted by rtvservis View Post
    Yes, you've made some nice photos but the one that would
    have interested me the most, is photo of the bottom casing.
    Is there an opening - with solder links? I've managed to
    remove codes through soldering links, but I can't remember
    if this applys to your model of Sony.
    bonus2010's Avatar
    Scotland
    Ignore previous post, you have supplied photo
    of bottom casing - not the radio I thought
    it might be.
    Sorry
    tvzmaj's Avatar
    Serbia
    Sony CDX-M800
    Code: 0211
    rtvservis's Avatar
    greeting, I managed to unlock the radio, I had problems with finding eeproma 24c02, mostly everything works great, and the code of, thanks to all
    tvzmaj's Avatar
    Serbia
    SONY CDX-M800MP CD/MP3
    In tuner is memory ST24C02.
    bus is connected to processor : 33 pin is SDA ,34 pin is SCL.
    To programmer connected only GND,SCL,SDA.
    Radio is NOT connected to power supply !!!!!!
    Memory is permanently connected to internal batery.
    enter code with key DISC+ and - ,SEEK + and - ,confirm code with key ENTER.
    You must remove front panel ,after CD mechanism. It is all.
    click
    dashradio's Avatar
    Inafield
    Default Code without stripping
    Hi, this radio can be done without stripping down just cut the 7th to 11th slit on the bottom lid, where you see the tuner pins, so that you can solder on to the end two pins which are SCL & SDA also put ground to case, power set for 10 seconds before you do a read, then switch power off then read code. Job done in approx 5 mins.
