Page 6 of 6 FirstFirst 123456
Results 76 to 83 of 83
  1. #76
    racin-snake's Avatar
    Jun 2009
    [ame=http://www.youtube.com/watch?v=Z18XMgMBAGw]Using ADP-019 29F400BB on GQ-4X programmer mcumall - YouTube[/ame]
    been usin this for about a three years now does the job well
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
  2. #77
    PierreTheron's Avatar
    Centurion,South Africa
    Quote Originally Posted by racin-snake View Post
    This straight adaptor works well . at least got contact on bottom of pins as well.
    PSOP44 socket adapter for chip programmer
    Certain you can remove old adaptor for willem and install this one.
    Otherwise buy solder on adaptor.
    Regards .
    My problems been solved with double contact adaptor now .
    Do not need to have lost time anymore on read and write these pescy bastards..
    Pierre
  3. #78
    Today I tried to write AM29F400 with willem pcb 5.5c,
    Chip ID- ok
    Read OK
    Erase OK
    Blank Test Ok
    Write - Error at 0x00000000 Chip 0xc7 buffer 0xff ?
    I select Fast Programing and than it stops at 4% with error at 0x005768
    do I need 12v to write ? This 5.5c is powerd only by USB
  4. #79
    Quote Originally Posted by donesko View Post
    Chip ID- ok
    Read OK
    Erase OK
    Blank Test Ok
    solved, just connect psop adapter without connectig 8pin ribon cable
  5. #80
    Aug 2016
    whats the best programmer at the moment for read/write 29f400/29f200?
    no matter how much.
    thx
  6. #81
    Sep 2021
    Video from carlambimmo show read and write 29f400 by labtool-48uxp!
  7. #82
    Mar 2020
    in the field
    hello I use tl866-IIplus seems to be a good and cheap programmer
  8. #83
    Sep 2021
    I think labtool-48uxp is the best for flash 29f series !!!
