Is a good question, i need help too
thank you very much
thank you very much
You need someone who can provide the incode (the outcode that Clip provides changes after 30 minutes) and immo code.
Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
24 digits out, 13 digits in with a 1 hour max time for coding. Done loads, the weekest link being the Renault server which is less reliable than their cars.
CLIP is way too clumsy for this job though, any number of after-market stuff is better.
now it is more complicated than you think..... from renault.net you don't get the immo code anymore, they only give you the code based by vin and the outcode.... the are getting more and more complicated.... if you use a older version will only ask for immo code, and you are done.
So, using an aftermarket tool, you still need the same in/out codes with a 1hr time frame? If this is so, we are still tied to the dealer then.
I'm not familiar with the Renault explorer or Abritus72 Avdi interface. Would anyone recommend the SSB or the T300 for renault key card programming?
hi if your card is still working you can cut it open neatly and transfer the pcf 7946 ic inside to the new card and the car will still work 100%. you need the pincode if you try to program with t300. the only way of extracting the pin is from the uch. 112 pin mask 3k91d or 1k79x. read the dump and post here i can give you the pin from the dump. you can then use T300 to code the card in.
hello I'm interesting to buy CAN Clip i have a ICC.
And my question is whether CAN Clip read eprom for ecu or uch??? Then I calculate PIN for this eprom.
hi
can clip only programming and diagnostic NOT read eeprom
regards
hi
If I extracting the pincode from uch, can I use Clip for programing new card?
Thx
if you need to use clip use an old version, try V48 or something around there then you only need the 12 dig code.
( see also vevepatronu post )
if using clip with outcode/incode then must use genuine key preordered from renault
