Results 1 to 5 of 5
    Jun 2010
    Default Original Starview 5 Firmware Firmware Installation
    Hi all
    I recently purchased a new Starview 5, when I first set it up prior to uploading the latest firmware I did noice that it made a funny noise when the Video wasswitched on. I didn't think that much f it at the time. after upgrading the firmware to the latest one and receiving all channels I tried to record a program through the VCR, however there seems to be a problem as when I switch the video on I get no sound but a picture.When I switch the VCR off it all goes back to normal. I have checked all connections and they seem ok.Two questions: Does anybody know what be causing this and 2:
    If I need to return this too the seller I need to reinstate the original Firmware that came with the box, can someone please advise me on how to do this and how I locate the file to upload as I guess if I return the box with the revised firmware the seller will know I have tweeked the firmware and may refuse to replace the box.
    Please help!
    Sep 2008
    after you flashed box you should have done a factory reset and a fresh auto scan and keycode enable,are you using cheap scarts as they not be fully wired,i dont think you will find the original file anywhere.
    Jun 2010
    Thanks a bundle i will try the new scart leads and if no joy then will do the factory reset if all else fails. Am usingh the same scart leads that I had on my EuroVox and that was working fine
    Dec 2008
    is new software work with n3 or not
    Jan 2009
    Unhappy
    Quote Originally Posted by dsamadabadi View Post
    no m8 no fix
