Results 1 to 8 of 8
    koziolek's Avatar
    Under the car
    Default 2000 BMW 540 DSC problem
    I just scan the vehicle has two error codes
    inpa shows :
    58: Gear box control unit error message
    97: Steering angle adjustment nesesery .
    Dis V44 shows:
    3A Message from EGS control module DSC passively switched No ABS control stop.
    61 Steering angle sensor identification DSC passively switched no ABS control
    when I go farder i get info The traction control module has dedected the absense of incorect message from partner control module
    EGS send message incorrectly
    Can Bus defective
    any idea any help what should i replace first any one has similar problem?
    Seville
    I would start by clearing codes and trying to adapt the steering angle sensor, if that fails then you will need to replace it.
    koziolek's Avatar
    Under the car
    so You mean steerig angle sensor is the probplem?
    how about Gear box control unit error message?
    obdmaster's Avatar
    Never never land
    Question
    Does speedo go off, is communication to ABS intermittent? Im asking as gearbox error message may be because no vss signal from abs. Is ABS/DSC control unit bosch as these units are prown to failure.
    Just something to think about m8.
    koziolek's Avatar
    Under the car
    no problem with speedo
    Member sergiompais's Avatar
    Portugal
    Quote Originally Posted by koziolek View Post
    Had this issue previously with a 2001 X5 (similar system).
    I changed the steering angle sensor and still wasn't able to initialize it. The DSC unit then looked guilty...
    koziolek's Avatar
    Under the car
    so You mean DSC should be replaced?
    Portugal
    IF the initialisation of the steering sensor does not complete successfully even with another one, then the DSC unit is a solid candidate to be replaced.
