Results 1 to 8 of 8
    lwood's Avatar
    city of angels
    Default I'm tired of my airbag programmer.
    i have a Andromeda Research programmer. this thing is giving me nothing but trouble. i'm tired of it..it always gives me read errors. i loss lots of business .. i can't even read H8SX/1721 MCU.
    or some moto chips.
    ok guys i need your help i want to get the best airbag programmer money could buy??.. i see lots of people recommending elrasoft devices.
    1. what elrasoft programmer should i get that has support for the most chips? i live in USA so i usually work on japanese cars. and american cars. some european cars.
    2.. i want a programmer that will work for new airbag modules like 10 prius with chip H8SX/1721 MCU. basically a programmer that will support future cars.
    3.. also a programmer that will do on board reading and writing. i am not good with soldering.
    4. and where do i get the adapters for the programmer? on board adapters.
    thanks for any help
    DK Veteran milanista's Avatar
    Quote Originally Posted by lwood View Post
    or some moto chips.
    thanks for any help
    check the sofware from carprog.
    netherlands
    What are the better tools and/or software for srs airbag?
    Id like to invest in tools or software.
    I have tachosoft airbag and t-airbag, wellon programmer.
    anny advice is welcome!
    lwood's Avatar
    city of angels
    so the elrasoft programmers only deal with soldering?
    lwood's Avatar
    city of angels
    i bought the carprog. i have a problem. the adapters that came with programmer dont have clips .. there is no way to connect to the chips? what is a good website to buy all the clips and micro test clips? and cable?
    i want this cable and the micro test clips. i dont know the name of the cable, if i did i would do a google search.
    Top Poster + jimthejock's Avatar
    Scotland
    if you dont want to solder why do this work as everything needs soldering at some point
    it is simple to take an 8 pin eprom chip off to read it there is nothing complicated in doing that ,why do you want to clip on to the chips, when you clip on you are powering up other items on the board and this can lead to corruption on what you are reading and destroying the information before you see it
    the andromeda programmer is a load of complications that do nothing really as ive tried one and it was useless change it for something that doesnt work on a dos system there are many around and buying cheap will always lead to problems...... good tools give good results the car prog will read the eeproms on board if you buy the adapters they sell, for the processors remember that they are always covered in varnish or similar stuff so follow the pins you need to somewhere on the board and solder there instead of direct on to the pins and try to remember that you have to learn to walk before you can run
    Jimmy
    shumo7722
    Guest
    the probes that your looking at are pretty expensive around 230usd. you can buy them on EPROM PROGRAMMER DEVICE PROGRAMMER BY ANDROMEDA RESEARCH thats the only place i know of. p.s. there progger aint that bad.
    Top Poster swat cat's Avatar
    Aug 2010
    Romania, Bucharest
    i have a little question... can i program a m95640 on the bord without desoldering it? i will use a willaem programer
