Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Member jazzmanthe's Avatar
    Mar 2009
    North East Scotland
    Think they must have been doing something with the keys last night, as they were clearing then encrypting again
  2. #17
    Jun 2009
    Quote Originally Posted by sebaru View Post
    I tried to enter the latest keys for digi, but still no working! Any ideas? Many Thanks
    I"v just checked and most of digi is still open with the sa4fun softcam.check you have correct patch that AU is off in options and that you unzip before loading I"m using atm6800&tm5400ci and both clear ok.baashi do not use biss menu you can open the cam with notepad and enter the keys manually in cas menu use ident 2011/2111
  3. #18
    Aug 2009
    hi Dick b, i am using a tm6900 combo+, and all digitv channels are locked. i am using the latest softcams from sat4fun.can can i do?
  4. #19
    Jun 2009
    Quote Originally Posted by divinetong View Post
    yeah I"m not sure why some are still working and others not but I believe all are supposed to be closed now. ask in the normal technomate section there are a couple of experts that may be able to answer you.
  5. #20
    Mar 2010
    Derry
    Quote Originally Posted by dick b View Post
    Hi, a quick question if you dont mind - what doe AU refer to?and you say to have it off - i thought that it should always be on?
  6. #21
    Jun 2009
    AU is auto update and needs to be off to avoid conflicting keys.
  7. #22
    Dec 2008
    Keys have changed again.
    Please use discusion for chat not the softcam file section.
  8. #23
    Jan 2009
    new softcam please thank you
  9. #24
    Mar 2010
    Derry
    My 5400+ is still clearing - strange one, really - a couple of mates have the same box (same model, but about 1 year older) and they have both lost Digi and the latest softcam cleared one box yesterday but they have gone again today?
    And when he tries to patch the box using a USB and firmware, he gets a message saying incompatible - I was putting it down to an error with the USB stick.
    Any thoughts?
  10. #25
    Aug 2009
    Default How to go back to original firmware
    Hi there, tell your friend to download the latest firmware, and unzip the firmware into a Usb stick. plug in the usb stick into the receiver. turn off the receiver completely, i mean turn it off from the back, and unplug it for about 15seconds. plug the receiver again but do not turn it on from the back of the receiver. now, pressing the menu button at the front of the receiver, turn on the receiver from the button at the back, while you are still pressing the menu button. the receiver will go into the loader mode.from here, u should choose the option to download file by browsing the usb stick. u can go to where u put the unzipped firmware file in the stick by using the remote control or the scroll buttons infront of the receiver. after updating the firmware, reset the receiver, and it will work again. u can now search on the net for a patch and softcam for your receiver. good luck. i had the same problem with my TM6900 pvr combo+, and it is working perfectly now.
  11. #26
    Newbie nufcsteve's Avatar
    Sep 2009
    Default TM keys
    Quote Originally Posted by benny/9 View Post
    tm softcam 11/6/2010
    for the following tm models
    1000, 3000, 5200, 5300, 5400, 5600, 6800, 6900
    digi-tv 01 key added to the file
    Hi benny, my 3500D not clearing, i read that 1W gone nagra 3 but some people still getting the channels, supposed to be a problem with the patch, any truth or ideas plz m8
  12. #27
    Dec 2008
    Discussion section for discussion please, file sections for files.
  13. #28
    Feb 2010
    Default re tm6800
    very very new to the digital world.Do i need to install the patch before adding soft cam keys
  14. #29
    Dec 2008
    See post above yours.
