Results 1 to 12 of 12
    Junior Member morbius's Avatar
    Jan 2009
    Default Fiesta Air Con Problem
    My son has just got himself a fiesta 1.4 with air con but the air con isnt working. I assumed it just needed charging so bought a kit to do it but when I checked the pressure it was already over the 30 PSI mark so I assume the charge is OK. The clutch doesn't click in and out as you would expect. I compared it with my wife's fiesta and that starts at the same pressure but when the compressor clutch clicks in the pressure rise to 40 PSI on that. Getting a bit out of my depth now so does anyone have any ideas what it might be or know a good air con man in the Liverpool area.
    DK Veteran cristec's Avatar
    Sep 2009
    Essex, UK
    What year is the car?
    Semper in Excreta
    Jan 2009
    Its a 2006 but looks the same set-up as our 2003 model.
    May 2010
    Have you checked all fuses on A/C? Dose light come on when you turn A/C on?
    Jan 2009
    The light comes on and I could only see one A/C fuse on the fuse board and that seemed OK, 10 amp I think.
    May 2010
    check the sensor of the low pressure. below the pressure 1,5 bar the compressor is switching off
    check the winding of the tubule of the compressor
    does the fan of the radiator work?
    Jan 2009
    Just been in the car again you can hear the clutch operating but still no cooling. I guess the best think might be to get it re-gassed professionally and see if that does the trick.
    Fordracer4life's Avatar
    May 2010
    under the sea
    Default ac
    30 is two low to start up. Hook that can up start the car. turn the ac switch on, open the valve on the can holding the tap up so only vapor not liquid gets pushed into the system and let the car suck it in. It will take a minute or two.
    Jan 2009
    Thanks racer I finally got around to trying the kit and within a couple of minutes the aircon was blowing cold again. Well pleased.
    May 2010
    I hate those DIY recharge kits ! Look under the bonnet for the yellow sticker that tells you how much refrigerant you should charge it with in grams ......... right, now then how much have you put in with your DIY kit ........??????? and how much was there in before you put some more in ??????? my advice get it checked correctly.
  11. #11
    May 2010
    under the sea
    As far as do it your self kits they work great as long as the system is not completely empty. If completly empty it will need to be vacuumed to remove all air and any possible moisture. I allways add untill the high side psi. is ambient temperature [farenheit] times two plus ten percent with the compressor on and the condensor cooling fans running. low side should be 20-30 psi running. If high and low are to high you have to much in the system, contamination or lack of air flow acroos the condensor. Stay cool and support diy!
  12. #12
    melmar's Avatar
    Dec 2009
    melksham. England
    If you like the diy kits you should stock up, don't think they
    will be for sale next month, the safe handling of refridgerant
    law comes in, and that should end there sale...
    in this case diy should stand for 'don't involve yourself',
    the gas is dangerous in the wrong hands, one spray in your
    face and the fluid in your eyes freezes,
    just treat it with respect if your doing it yourself...
