mentos (4th April, 2013), mihaiservice (20th November, 2013)
iI have Buy a Cardaqplus Interface with Software MAN CATS 9.02, Setup Instruction, WIBU Codemeter Files, the Systemsoftwre is Protected with WIBU-CODEMETER Dongle.
I pay 3000 Eur but work fine!
The Cardaqplus Interface and the MAN CATS2 Software working with the Newest and Older Trucks and Neoplan Buss, same Function as the T200 (Man Cats II is older Modell not work with Trucks wirh CAN BUS)
The Problem is the WIBU Codemeter so I have hier Upload the MAN CATS DVD Revision 9.02, the Setup und File Instruction and the WIBU Codeme Files.
maybe guys this can one crack it so that all user can work with this Software and a regular Cradaqplus Interface!
Hier the Links an don?t forgot THANK?S!
Hier the LINKS:
- The Setup Instruction in english of This Programm and the Files - 28 MB
http://rapidshare.com/files/390731603/MAN_v902_2166.rar
- The WIBU Codemeter - all Files (from my Dongle 100% work)
http://rapidshare.com/files/390727467/settings.ini
http://rapidshare.com/files/390727466/codemtr.io
http://rapidshare.com/files/390727464/NoFlash.io
- The Software MAN CATS Software
http://rapidshare.com/files/390740660/MANCATS_V09.02.00.part1.rar
http://rapidshare.com/files/390762324/MANCATS_V09.02.00.part2.rar
http://rapidshare.com/files/390770429/MANCATS_V09.02.00.part3.rar
P.S. don?t aske me for WIBU Codemeter USB Dongle for sale I have only my personal USB
Dongle and i will not sale this, maybe the guys hier can crack it - good Luck !!!!
Best Regards!
thank you man
thanx man i think MANdll.dll file should be replaced with another one with no codemeter information
Hello My friend,
Thanks for upload.
Can you send us the adapter cables diagram / schema ?
Because Car-DAQ obd is not standart.
from Car-DAQ OBD to MAN OBD
From Car-DAQ OBD to 12 pin
I have cardaqplus. This Files can work on my device?
THank you for the help.
I was confused on the partition process..Not really sure how to do it. If anyone could give me a heads-up, thanks.
1.) create partition C,D,E on your computer (if your Cdrom is E , go to Device manager and disable Cdrom , and create partition E)
2.) create E:\MAN CATS II directory
creat partetions C D E on your lap top install windowes in partetion C after finish you open partetion E it will be Empty right click on muse the select new folder the rename the new folder with MAN CATS 2
you use any partetion softwear
Insert windows xp cd
1. boot from cd
2. delete the partitions that you have
3. Make three new partitions C,D,E
4. When it asks select the partition you want to set windows on to you select C and press enter after about 45 min the installation is completed.
by doing this you will lose all data you have on your hard drive, so make a copy of it.
