Page 5 of 15 FirstFirst 12345678910 ... LastLast
Results 61 to 75 of 214
  1. #61
    If you have already installed a USB-to-Serial converter and the Florida Probe freezes in the calibration routine, you will need to download this replacement driver file: ser2pl.sys
    This file must be placed into the C:\Windows\System32\Drivers folder for Windows XP, ME or into the C:\WINNT\system32\drivers folder for Windows NT, 2000. Windows will ask if you want to replace an already existing file with that same name in the destination folder. It will show that the file you are replacing is smaller than the file downloaded here. Click 'yes' and restart your computer.
  2. #62
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    for anyone who needs this info and drivers for a usb to serial converter here are the drivers for both XP and VISTA. make sure you use the correct file for your computer O/S
    usb to serial convertor
    this is a driver file for a [usb to serial convertor]
    this is to enable you to use a [ laptop without a 9 pin com port] . to use a null modem cable to programme your receiver. it says plug and play on these devices, they dont and you need a driver, so if your device came without a driver disc use this it works 100%.
    [1] open and run the driver file with the device unplugged
    [2] it might ask you to uninstall old drivers [say yes]
    [3] re-start your pc after installed.
    [4] connect your usb to serial device.
    [5] check in the device manager settings
    [ prolific usb to serial com port.-com [1].
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
  3. #63
    Jan 2009
    Flashed my eurovox yesterday, using the guides the only problem was getting my laptop to use the USB serial and nul modem cable.
    As this was a cheep cable from flebay it came with no drivers, after searching for about two hours and trying six or seven I foung the one i needed. thought I would share this as the drivers i found on here did not work for me.
    The usb port has the numbers HL-340.The driver can be downloaded from-
    http://www.winchiphead.com/download/CH341/CH341SER.ZIP.
    I hope saves someone some time.
  4. #64
    Jan 2009
    Thanks. Had one of these for over a month but not tried to use it until tonight!
  5. #65
    DK Veteran Lanxman's Avatar
    Lancs
    Jan 2009
    I have the same problem, gonna try a few of these downloads and post back if i can get it working.
    Many thanks
  7. #67
    Jan 2009
    I have the same proablem with these kind of driver rs232 but on the cable it is write HL-2303 and none of the drv. from the cd cable won't install on xp (and i am very experinced with installing driver on xp )
  8. #68
    Jan 2009
    There is a few posts with drivers. Which one for the maplin usb please?
  9. #69
    Lancs
    Quote Originally Posted by spiderman01 View Post
    Her you go mate.
    Digital Kaos - Downloads - Maplin serial converter
    Sometimes a slow gradual approach does more good than a large gesture.
  10. #70
    Jan 2009
    Default RS232 CABLE DRIVER!!
    hi, evry1, well i bought a HL RS232 CABLE from internet. when i connect to my laptop its says unknow device. i tried to update the driver but it says window already installed good driver..
    i tried so many drivers but cudnt sorted out..
    i m using window vista 32bit
    can anybody help me out..please
    thanks..
  11. #71
    Default Drivers for usb to rs232
    Please install the software first and then plug the cable when asked and follow the instructions....
  12. #72
    Default Driver for usb to rs232 serial HL
    Hallo every one ,
    Please install the software first and then plug the cable when asked.....
  13. #73
    V.I.P. Member wilf's Avatar
    Jan 2009
    uk
    Hi there m8, you need to contact a moderator and get you user name changed this will make you traceable to anyone looking in.
  14. #74
    Feb 2009
    Hi all
    Yes I need the drivers too, but you have to post first.
    Just thought I'd take this opertunity to intyroduce myself
    Cheers
    Lee
  15. #75
    Feb 2009
    Quote Originally Posted by reddave View Post
    Here are the drivers I use.
    Hi All
    I am trying to get the driver you guys have posted, however, the moderators say I cannot get them, Does anyone know why, do you have to post 15 or so times first.
    If so couls someone please PM them to me
    Cheers
    Lee
