Results 1 to 8 of 8
    Aug 2009
    Hampshire
    Default how do you read mc68hc05x16?
    hi
    i have upa, im trying to read the above ic dj62,but no luck ,on the upa help diagramm ,pin 19 and 21 go to p6,is that mean both have to be connected to the p6?also is it safe to read these in circuit?
    also trying to solder some pins to the board are these available to buy or what is the best material to make them pins?,thnx inadvance.
    nazz2
    Nov 2009
    Portugal
    Hi friend.
    Upa is able to read it.
    You must do like it tells in the pdf, booth pins connecting to the UPA wire number 6.
    After that you must go to the connections menu and see the connection that are with red color.
    If you have red color it means it is not ok to read so you must start to lift the pins.
    For example, if you have TXD at red you must lift TXD pin from the MCU. Try one by one until all connection appear green.
    This MCU you can read in the circuit.
    Best Regards,
    Nuno
    Aug 2009
    Hampshire
    Hi nuno
    Thanx very much for the tip i didnt know about lifting pins when reads red,very usefull,so basically lift the pins that are red,could be any pin,also since there are 9 wires to solder,and the ic is a fine pitch,do you recomend any solder pins,or a best way to solder these wires to the board,thanx again.
    nazz2
    odyseus7's Avatar
    GREECE
    lift 19 and 21 and connect together.The crystal 8000.
    Nov 2009
    Portugal
    When you lift pins you must connect the programmer wires to them. Its the same thing but you will weld the wire to the lifted pin and not in the board.
    Tomorrow at work I will take a picture to an MCU I must read with lifted pins.
    Regards,
    Nuno
    Nov 2009
    Portugal
    Default Upa reading example
    Hi friend.
    Sorry the delay.
    Like promissed here is a photo using UPA to read.
    Example_Upa.rar
    Stay well.
    Regards,
    Nuno
    Is it possible to read MC68HC05X16 with XPROG-M?
    If possible, is it in-curcuit or on-board?
    Jul 2010
    ALGERIA
    very easy on-bord
