Results 1 to 13 of 13
Hybrid View
    Jan 2010
    Default Corsa C Easytronic Problem
    Hi..
    I have a problem with the system EASYTRONIC, in corsa C 2001 1.2 z12xe, which shows F in the display, and the car stops working.
    not show any error in the engine or the easytronic.
    I think it is a problem of the actuator, and would appreciate if someone has some information to repair
    May 2010
    w.yorkshire
    i had one that turned out to be reverse or brake light bulb....strange but true. regards steve
    Jan 2010
    Quote Originally Posted by digi-dash View Post
    yes, this car has been towed several times because of blown bulbs, but unfortunately now has a bigger problem!!
    thanks for help
    Ashraf6119's Avatar
    Nov 2009
    UK
    Yes his right check also if the Brake Light Switch is Working.
    But, most of the times its those two motors which are on the Gearbox they do give problem try tapping them gently and see if that F fault clears and lets you to start the vehicle.
    Ash
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    Meat-Head's Avatar
    Quote Originally Posted by Ashraf6119 View Post
    Could be baulk rings in furry box making motors draw excess currants stopping it working.
    Bad earth to module on box, bad pos - ALLSORTS of things and they stop working.
    Ashraf6119's Avatar
    Nov 2009
    UK
    Quote Originally Posted by Meat-Head View Post
    MH,
    At this age Corsa C 2001 you looking at Carbon Brushes in Motors worn out.
    Ash
    Thanks Ash
    Meat-Head's Avatar
    MH,
    Ash
    Maybee, but has it been used by Petula Clarke just to go downtown. Or has it been used by Roy Oberson who just drove all night on the motorway? Like a dynamo or starter or dynastarter it may have been replaced already!
    There is a test flow sheet you can get by *THINK* it's (NO) Luk - whoever makes the system
    HTH
    Meat
    Meat-Head's Avatar
    Quote Originally Posted by rukass View Post
    Let us know what it was and how much it cost you and how long it took to repair
    May 2010
    w.yorkshire
    check fuses f32 f51 and f54 for continuity and +12v. also ep7 under centre console in car and ep9 near battery for good clean contact, regards steve
    Meat-Head's Avatar
    Could you explain in more people for members who are confused what you are refefing to
    obd socket batteryy off - do the hokey cokey with your scanner plug
  11. #11
    May 2010
    w.yorkshire
    ep7= earth point 7, it is located behind/under centre conole (where stereo/heater controls are.) ep9 is near car battery. these will be wires bolted to body of car. remove/clean terminal and car body with wire brush on drill/put back. bad earths are responsible for lots of faults on cars and as the repair is free and easy it is good practice to start with the fuses and earths for 10 minutes before digging deeper, hope this helps, regards steve
  12. #12
    Newbie darksawa's Avatar
    Nov 2009
    Russia
    There are some main troubles with easytronic, but first of all you have to read fault codes from easytronic control unit.
  13. #13
    May 2010
    w.yorkshire
    if still not fixed let us know. several times blown bulbs???? maybe prob in bulb circuits? does easytronic comunicate with tester? if not check power and earths as above. what tester are u using? does it support any live data on easytronic? if sorted please post cure to help others, thanks steve
