from what car is this bsi?
BSI module Valeo
REF VALEO:730 060 12
REF DAV:A11973
REF SYLEA:142 785
REF PSA:96 424 096 80
02/150/N
BSI-BOITE M1
HARD:PR4
SOFT:V8.2
data is stored in processor NEC 780949 (100 pin)
NEC JAPAN (75076303)
with upa click to read
error
Baudrate capture error
not reading NEC 780949
help me
Hi friend.
You can have 2 problems.
First you must check if you need to do an auto baud rate before try to read, if so the option appears in a button "Set auto baud rate" and Upa device automaticaly calculates the freq. to read the processor.
In the must part of the cases Upa is not able to read the NEC processors, it is better to use the NEC programmer.
Best Regards,
Nuno
Where is the best place to buy upa programer that works.
from author,Penko Kovatchev,ELRASOFT Products
regards Gepa
Hi Gepakg.
That is true that UPA makes a lot of UPD NEC but not all NEC processors.
I work with car and robotic electronics, with NEC I find in cars there is no problem but there are some NEC processors in Robotics we can not read them with UPA.
Regards,
Nuno
Is it Berlingo 2001 or Picasso raise Pin 11 and Reset dessolder
0 Ohm resistor read sure without PROBLEMS
hi all !
I find this NEC JAPAN (75076303) in one Pegeout Partner BSI and i whant to program it. It is the same with
NEC 780949 (100 pin) or i can program it as the NEC 780949?
Best Regards,
Flaviu
With Clone Nec adapter u can't read anything.
UPA clone is also junk.
Must use original tool not chinease bad copies.
And of course must learn little bit more.
Simple as that
If u need original device contact me On PM
Sent from my HONOR 8X
Dear all, i also fight with baudrate capture error, finaly found empty flash on 78K0 adapter.
Check this thread: https://www.digital-kaos.co.uk/forum...PA-nec-Adapter
Hope will help to most of you.
Milan
garric (16th October, 2023)
