Results 1 to 13 of 13
    DK Veteran tesla001's Avatar
    Turkey
    Default upa baudrate error
    BSI module Valeo
    REF VALEO:730 060 12
    REF DAV:A11973
    REF SYLEA:142 785
    REF PSA:96 424 096 80
    02/150/N
    BSI-BOITE M1
    HARD:PR4
    SOFT:V8.2
    data is stored in processor NEC 780949 (100 pin)
    NEC JAPAN (75076303)
    with upa click to read
    error
    Baudrate capture error
    not reading NEC 780949
    help me
    calin_bm's Avatar
    Jan 2010
    near civilization
    from what car is this bsi?
    Nov 2009
    Portugal
    Hi friend.
    You can have 2 problems.
    First you must check if you need to do an auto baud rate before try to read, if so the option appears in a button "Set auto baud rate" and Upa device automaticaly calculates the freq. to read the processor.
    In the must part of the cases Upa is not able to read the NEC processors, it is better to use the NEC programmer.
    Best Regards,
    Nuno
    gepakg's Avatar
    Feb 2010
    Serbia
    UPA-USB give only that possibility to set automatic baudrate,must check all connections if it is one of first 8 bad that message apperas...
    it isnt true that upa can not read some of nec uPD,a`ll do more than 100 and always with success!
    regards Gepa
    Quote Originally Posted by carsolution View Post
    Hi friend.
    Best Regards,
    Nuno
    311786's Avatar
    Jun 2010
    Where is the best place to buy upa programer that works.
    gepakg's Avatar
    Feb 2010
    Serbia
    from author,Penko Kovatchev,ELRASOFT Products
    regards Gepa
    Quote Originally Posted by 311786 View Post
    Nov 2009
    Portugal
    Hi Gepakg.
    That is true that UPA makes a lot of UPD NEC but not all NEC processors.
    I work with car and robotic electronics, with NEC I find in cars there is no problem but there are some NEC processors in Robotics we can not read them with UPA.
    Regards,
    Nuno
    gepakg's Avatar
    Feb 2010
    Serbia
    yes,but UPA is designed mostly as automotive electronics tool and support mcu in it...
    NEC uPD have many,any tool support it all...
    regards Gepa
    Hi Gepakg.
    Regards,
    Nuno
    Dec 2009
    Is it Berlingo 2001 or Picasso raise Pin 11 and Reset dessolder
    0 Ohm resistor read sure without PROBLEMS
    Mar 2010
    hi all !
    I find this NEC JAPAN (75076303) in one Pegeout Partner BSI and i whant to program it. It is the same with
    NEC 780949 (100 pin) or i can program it as the NEC 780949?
    Best Regards,
    Flaviu
  11. #11
    Hi friend.
    Best Regards,
    Nuno
    Hi Nuno
    were do you set auto baud rate on upa usb options ?
  12. #12
    Jan 2010
    Trstenik - Thun
    With Clone Nec adapter u can't read anything.
    UPA clone is also junk.
    Must use original tool not chinease bad copies.
    And of course must learn little bit more.
    Simple as that
    If u need original device contact me On PM
    Sent from my HONOR 8X
  13. #13
    May 2010
    Czech Republic
    Dear all, i also fight with baudrate capture error, finaly found empty flash on 78K0 adapter.
    Check this thread: https://www.digital-kaos.co.uk/forum...PA-nec-Adapter
    Hope will help to most of you.
    Milan
  14. The Following User Says Thank You to m_toy For This Useful Post:
    garric (16th October, 2023)
