hi can you plaes tell me whare to put or how to yous this files
New Favourites channellist panel
This plug-in provides an alternative to the favourites channellist in the firmware.
Its main advanteges
- Sorts your favourites groups as defined in PCEditor
- Allows to switch channels in PiP or live mode (and filters channels which cannot be opened in PiP mode).
So it can also be used as alternative to the Sub channel list.
Key Mapping
Up/Down -> figure it out yourselves
Left/Right -> jump 5 entries in list
Red/Green -> change Favourites group
Blue -> switch live/Pip mode
Licence
GPL
RELEASE 0.5.1
- fixed panic when /var/theme folder is not present
- automatically jump to currently active group and channel on startup
Enjoy it,
pacco
Hi @italiaboy,
With an ftp programme, copy favpip.plugin to var/plugin
Then at your box menu, go to plugins and you will find it there
ok many thnx mate
can someone help i have the 910
and have download de fils
but have
favpip-v0.5.1
favpip-v0.5.1.bak
i have put it in var/plugins and nothing have change extension to plugins
and see it in my plugins via menu bud cant acces it
what am i doning wrong
RELEASE 0.6
- show epg next to channel names
Ok I hope this works
RELELASE 0.9.1
- configuration files can have line end in both formats 'LF' or 'CRLF'
- favpip.config is looked for in plugin folder, which is defined by sbox. Should work on DGS and ABCOM firmware.
- header shows positions of SCRAMBLE and HIDE icons.
- HIDE icon in header represents state of hidden channels visibility.
RELELASE 1.9.0 - RC for 2.0.0
- whole code was rewritten and now is using widget libraries.
- no more global variables
- navigation is now 5 times faster then in previous ones.
- new configuration options for fonts setting added. They still need to be fixed to check border values.
RELELASE 1.9.3 - RC for 2.0.0
- transponder is now set correctly in live channels, so pip filter works good.
- switching to second empty group when empty groups are shown was not possible, not it is fixed.
tx gonna try this plugin :-)
