right ive seen too many people thinking that they need to add a new image, nothing is further from the truth, you only need to add the new fix file to your old image.
now im presuming that some people might find the idea of flash fxp (ftp) a bit daunting if they have not used it before so heres a little help.
this is based on my set up of pc/router/dreambox . pc goes to router,dreambox goes to router (note the ethernet lead port on the back of your dreambox.)
right to start we need to fire up flash fxp, it will look like this once you start it.
once its opened you will see on the right hand box a sybol that looks like a thunder strike, click on that then quick connect and you will see a box like this.
right at this part you need your ip addy of your dream box, to find this go into the menu on your dreambox, scroll to setup then scroll down to expert setup,then communication setup, theres your dream box ip, write it down and go back to your flash fxp.
enter your ip into the server or url box.
under user name enter
root
under password enter
dreambox
click connect.
presto a list of files from your dreambox should appear in that right hand box that looks like the pic below, you are connect to your dream, good job!!.
now we need to navigate to
var, look down that list of files in the right hand box till you see var, click on it, now you should see a list of new files, look down that list and you will see
keys, click on that, again a new list of files will appear like this.
now we need to add the new file for the fix.
so now look into the left hand box in flash fxp these are places on your pc, you need to navigate to the place you downloaded the fix file to (if its easier leave the unrared/un zipped file on your desktop), once you have found the file select it by clicking on it, once selected right click on it with your mouse and a drop down box will appear, at the top of that box you will see the words
transfer. click on that and it will show a pop up box saying something like overwrite same content, select yes (this overwrites the old file with the fix file.
once this is done shut down the fxp software and reboot your box and or emu.
congrats you,ve just fixed your box and not spent a penny doing it.
