IP address on dreambox
Results 1 to 7 of 7
    Apr 2008
    Default IP address on dreambox
    The IP address on my dreambox is 10.0.0.97 is this normal?
    Apr 2008
    That depends on your router, mine is 10.1.1.23.
    Do you have DHCP enabled?
    Apr 2008
    it can be any thing as long as on your network, u can change in menu on box
    Apr 2008
    I dont have a router and what is DHCP ?
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    68
    As already said, the ip address can be anything you want.
    As long as the dreambox and PC are on the same subnet.
    There's more info about ip addresses here...
    http://www.digital-kaos.co.uk/forums...ead.php?t=1307
    Apr 2008
    Quote Originally Posted by ash1809 View Post
    Hi to make it simple set up ip address on you dreambox as 192.168.1.1 and on your pc as 192.168.1.2 use a netmask as 255.255.255.0 and you will be able to talk to it, if you are not using a hub/switch you will need a crossover cable, pins 3+6 to pins 1+2 and visa versa on both RJ45 Plugs
    If you are connected on broadband, and this is the address of your box check you computer ip on windows its ipconfig /all at the CMD prompt, on linux its ifconfig at cmd prompt
    hope this helps
    Apr 2008
    Dublin
    If you look at you wireless router status page (usually on 192.168.1.1 or 192.168.1.254, you should be able to identify an ip address assigned to 'dreambox'
