[29f400 with willem]
Results 1 to 9 of 9
    41
    Downloads
    18
    Uploads
    Default [29f400 with willem]
    Hi,i have to reprogramm a flash 29f400 with pbc 4.5 willem.
    This is my willem
    http://img101.imageshack.us/img101/6...prompcb502.jpg
    and this is the tsop 44 adapter for 29f400
    http://img12.imageshack.us/img12/146...154ad8b684.jpg
    wich is the correct position or memory and adapter on willem pbc,please?
    DK Veteran rsibiza's Avatar
    Downloads
    7
    Uploads
    Quote Originally Posted by marcoco View Post
    This is my willem
    Your flash has a dot on one corner,check if you have dot on your adapter for the 29Fxx,if there is no dot on adapter,turn you adapzer with the pinheader bridge upside,so it will be same side as zif socket lever,and the dot has to be down left,turned to you,but i will check at home to be sure.
    libya
    Downloads
    9
    Uploads
    check this
    ahadi's Avatar
    Jerusalem-Palestine
    69
    Downloads
    24
    Uploads
    Talking
    is there any way to read 29f400 tsop44 using wellon vp-280 , program list just support 48 pin
    50
    Downloads
    Uploads
    Everytime i use this to rread this type if chip, my laptop restarts
    20
    Downloads
    126
    Uploads
    This is my willem
    Hello
    For these adapters are very complicated.
    because you have bad contacts in pins.
    My advice is to use adapter where you can solder pins, and has no bad contacts
    Correct way for the band is the red line on the adapter and clk ck in willem
    Home
    15
    Downloads
    8
    Uploads
    daniersms's Avatar
    South Africa
    432
    Downloads
    31
    Uploads
    Maybe too long ago...............
    Love this forum
  9. The Following User Says Thank You to daniersms For This Useful Post:
    bobolin4o (18th November, 2016)
  10. #9
    Jun 2013
    EU
    1,163
    Downloads
    11
    Uploads
    Lol, only six year old thread.
    Bad if he haven't solved the issue since then
  11. The Following User Says Thank You to morgano For This Useful Post:
