Results 1 to 15 of 21
    Tunisia
    Default BMW EWS 3 2D47J ( erased)
    Hi all
    Customer came for spare Key, BMW 320D, year 1998
    contents of 2D47J (in BMW EWS 3 Hw: 02 SW: 05) is erased when I went to read it,
    How to solve this? , DDE is Bosch 0281001445.
    please any help is appreciated
    obdmaster's Avatar
    Never never land
    Question
    Are you sure its erased and not got security m8, how are you reading and with what?
    If it is erased you can order new ews box from dealers which will work with key straight away but will need synchronising with DDE. for vehicle to run. There around ?140 in the uk m8.
    Tunisia
    i am sure MCU eeprom is erased, i read it with omega,
    Can I use pair of dumps from same car (DME and EWS)? of course if i find this pair of dumps.
    Or is there virgin file for this DME,
    Wirral
    Omega reads these ok. Are you using skip security option before Reading? If you don't then yes you may have erased it . Try skip sec again
    Tunisia
    Quote Originally Posted by parapilot View Post
    i forgot to make skip security, i am sure it is erased
    Wirral
    Have you tried Reading again if erased it should read ok just be blank all ff etc. If mcu not respond clean up legs etc then skip sec , read. If it reads fine but dump blank you need new ews really unless you read ecu and someone on here can match it up. I only do lost keys on BMW to much messin on spare key.
    Saudi Arabia
    Quote Originally Posted by testourii View Post
    Post here DDE Dump let try if i can virginise or match it with EWS3 dump
    Tunisia
    Quote Originally Posted by MJPOWER View Post
    What IC in DDE must read, I saw an eeprom bosch B58253 (24C02), is it this one? or another IC?
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    in 0281001445 must read 24cxx and 2x 27c010 ...
    Tunisia
    Here is dump from 24C02 , 2 IC AM27C010, and 2D47J dump ( i recieved it from friend)
    waiting for your help.
    Tunisia
    no one can help?
    bram380's Avatar
    Indonesia +628153111774
    Try this dump:
  13. The Following User Says Thank You to bram380 For This Useful Post:
    t1tan1 (29th August, 2015)
  14. #13
    Tunisia
    Quote Originally Posted by bram380 View Post
    Try this dump:
    No changes to DDE dumps?
    does car need DDE - EWS synchronization with this dumps?
  15. #14
    Ukraine Crimea
    Write it in MCU..
    Pa soft 1.3.6 for DDE - EWS synchronization
  16. #15
    Tunisia
    Quote Originally Posted by airdrive View Post
    Write it in MCU..
    thanks, but 2D47J MCU eeprom is only 512 bytes, not 64KB!!
