Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
  1. #16
    youssef70's Avatar
    Sep 2008
    tunisia sbz
    Quote Originally Posted by testourii View Post
    thanks, but 2D47J MCU eeprom is only 512 bytes, not 64KB!!
    it can be 64kb if readed with etl
    if you cant extract it this is for you its only .512 kb
  2. #17
    Tunisia
    Quote Originally Posted by youssef70 View Post
    thx mate, but i can extract it,
    eeprom can not be 64 KB, etl read all memories in MCU, So 64 Kb contains : eeprom, flash rom, rom, .....
    EEPROM is ONLY 512 Bytes
  3. #18
    Aug 2010
    I have the same problem..
  4. #19
    3in1san's Avatar
    Nov 2009
    in the middle of europe
    Not need to write eeprom from other device. Eeprom can be filled with FF.
    You need to write sync code from engaine ecu to ews, or virginise it. And write keys to eeprom.
    PASoft 1.4 has all functions what you need. You need new transpoders becuse old has password and this password was delted with eeprom
  5. The Following User Says Thank You to 3in1san For This Useful Post:
    seregka (12th October, 2019)
  6. #20
    key-maker's Avatar
    May 2010
    hi all i have been face this problem after 3 years but i solved it
    * put any old dump from any ews3, in the erased ews
    * program new transponder
    * and make synchronization with any diagnostic tool ex GT1, Autoboss
    good luck
  7. The Following 2 Users Say Thank You to key-maker For This Useful Post:
    ranchero (31st August, 2021), seregka (12th October, 2019)
  8. #21
    May 2014
    Gaziantep
    While doing the 1998 model bmw 540i replacement key, ews 2D47J crashed when reading xprog and to ecu flash 29f200 dump and ews dump to vehicle set.
    how can you help
