Hi today I had Mercedes S-class there are some faults from injection are this correct?
P1403 Exhaust gas recirculation (EGR) system - malfuncion. Probable Cause: wiring, connectors, hoses, intake leak, EGR solenoid, MAF sensor.
P1470 Turbocharger (TC) boost presure - pressure too low/high. Probable cause: wiring, connectors,hoses, turbocharger (TC) wastegate regulating valve.
P0100 Mass airflow (MAF) sensor/Volume air flow (VAF) sensor - circuit malfunction. Probable cause: Wiring, MAF/VAF sensor, ECM.
P2204 Nitrogen oxides (NOx) sensor, bank 1 - intermitten input. Probable cause: wiring, poor connection, NOx sensor.
P1636 Engine coolant blower motor control module - malfunction. Probable cause: wiring, connectors, engine coolant blower motor, ECM.
P1481 Glow plug(s) - defective. Probable cause: wiring, connectors, glow plug(s), ECM.
also there was fault in other modules but I cant found description
ESP:
C1504 signal eror/ signal variation, signal missing.
electronic ignition switch:
B1010 : The supply Voltage of the control unit is too low (under voltage)
suspension:
C1026
C1122 AIRmatic: fault in component B24/4 (acceler. sensor)
C1517
C1013 terminal 30 low voltage
C1402
transmission:
P2502 The gear is implausible or the transmission is slipping
P2503 The gear comparison is negative or the target gear is not reached.
P220A P220A - Y3/6N2-Y3/6N3 speed compare implausible
P2600 circuit voltage too low
thanks for any help in advantage![]()
