have a mercedes benz 1995, C220,
vinWDB2020221F196836
MOTOR 111961
customer lost all remotes, i made a new key, but the vehicle cranks but doesn?t run. there are two lights in the mirror green and red both are blinking.
does anybody know a procedure to disable the alarm on this model without the remote ?
thanks in advance
mauricio
hi, just forget to said that i made a mechanical key, there is no remote,
mauricio
Hello, sorry push this topic again, i have the same problem but with a E220 1986, mechanical key and remote, remote battery new, open and close the doors but the mirrors leds green and red blink and the car dont start.
any ideia ?
thanks to all.
i have the same problem today no keys or remote flashing red green light. i cannot find immo off file for petrol bosch ecu only for lucas ecu. any one come across this!!!!!
regards
leowii
find the immo box should be on passenger side foot well . you should have sensors on the left and right of dash follow the wires . you will then see factory immo box and aftermarket alarm disconect aftermarket alarm and put original wires back to the immo box as they should be . unlock car with remote should start.
regards
ok, gona trie.
Think you may find aftermarket alarm and factory immobiliser are not linked to each other
You must remove ecu and immobox in the passenger side .
And a program off dump in the ecu and the immobox
ecu have Motorola HC11, immobox have Motorola HC05
if you can program this ask me for dumps
good luck
you can do it at any mercedes dealer
