Page 1 of 4 1234 LastLast
Results 1 to 15 of 60
    Default VCDS 908.0 German
    does someone have vcds 908.0 cracked in german? i use vag-com 908.0 and it works but it is in english, if i install vcds 908.2 from ross tech it detects my cable too but it says no connection with car. i tried also ignition off and on and then to connect but it doesnt work. and all i want is that i have 908.0 in german. please,does someone have? i think the cable is a china clone vag 908 because i got it with a little cd where vag 908.0 software was in.
    Ill be very thankful
    kind regards
    deleted --- links down
    Quote Originally Posted by ManXth View Post
    kind regards
    i think your interface is broken don?t use a clone interface with genuie Software.
    You can flash it to German when the SPIEN Fuse at the ATmega is enable.
    Germany
    kind regards
    Hi, I have exactly the same problem. have you found a solution? Gruss Marco
    -D-
    links does not go...
    you do not have permission to access this page.??????
    Can somebody these instructions reupload or send to me by PM?
    Jun 2009
    Find users RSIBIZA und ich denke, es wird dir helfen.
    Quote Originally Posted by vares View Post
    Hello.
    Can somebody these instructions reupload because I do not have permission to access this page:
    hier http://www.digital-kaos.co.uk/forums...taller-125865/
    Anleitung: Tutorial , VCDS 805 programming and upgrading
    Last edited by Dreamer; 15th October, 2010 at 12:54 PM. Reason: email address removed
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by mpmichu View Post
    Hello.
    Hi poeple.
    I will look how i can do that,but for sure i wont upload any soft or dump.
    Just a tuto how to flash atmega162...and 93c46...ftdi.
    If it was removed,there was a reason...i dont wanna work against a mod here here.
    So if info is needet,i do...if dumps are needet...i am out!
    Last edited by Dreamer; 15th October, 2010 at 12:55 PM. Reason: user mpm email adress removed
    Hi rsibiza.
    That was your greatest post. Can you post only images again
    Tutorial about repairing or upgrading VAG COM interface with 1.78/.179 firmware working with VCDS 805/812 english version.
    Firstly we must supply the interface with a voltage of 12 volts , for this we solder 2 wire on 7805 regulator like the picture :
    Attachment 6312
    After we must connect the ATMEGA 162 ship with port LPT of the PC to program it as shown on this pictures :
    Attachment 12129
    Attachment 6313
    Attachment 6315
    if you have no LPT port you can use USB programmer as explained on rs_ibizas post
    Final result :
    Attachment 6316
    The airbag controller is not needed , i use it only to test the interface.
    Danke f?r die Info, nun muss ich ja nicht mehr suchen.
    to rsibiza,
    I need none software, only info to programming atmega over LTP-Port, set fuses etc.
    -D-
    mrgaga, you do not have permission to access this page. This could be due to one of several reasons:
    1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
    2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation. Check your registered email address for an activation link.
    3. If you are trying to download files from the download section or download attachments, you are required to post on the forums before gaining access. After posting, your account will be upgraded within 15 minutes. Please don't post asking why you can't download, if you have posted, permission will be automatically granted.
    Why????
    can somebody read the links??
  13. #13
    I think some mods have deleted anything that has to do with vcds dumps.
    You get this message because the thread doesn`t exist anymore (I think)
  14. #14
    romania
    Default please help me
    i have a vag com 908 dual k & can china clone . working great whith vcds 908.1 908.2 ro .after upgrade program to vcds 1010 interface say :vag com hex can interface found not conected to the car. i have dump for atmega and ept for ft232 rl . how to reprogram this clone to be never bloked over the internet conection and i can use software from rosstech.
  15. #15
    Vag com umm a minefield of useless leads (so far ive tried 3 ) but why do they charge so much for the software $350 is really a but steep these days !
