Results 1 to 8 of 8
Thread: Prius SRS fail
    Member catalinux's Avatar
    Default Prius SRS fail
    I've just tried to erasea SRS from a S220 chip to get rid of airbag light on the dash, I had the possibility to copy from a similar device from another Prius all the data from the chip, and then copied to my bad chip. Surprize, didn't work. I'm new in this field & may be I did something wrong, I have a VP-290 Wellon Programmer, hex data to read the buffer, I copied the buffer from the good chip, I erased the bad chip and installed the buffer from the good chip, but didn't worked.
    Can anyone help me please, and say what I did wrong?
    V.I.P. Member patkins's Avatar
    Cuckooland Banana Republic
    Hi catalinux. Your question may not be seen here. If you could post it in the relevant auto section you will probably receive a quicker reply. Good luck.
    Thank you, i'll do that
    Portland, OR, US
    i would try to erase all EEprom memory and try how it works. if fail, look for codes, or replace the module
    maca's Avatar
    Feb 2009
    liverpool
    Quote Originally Posted by visavis88 View Post
    update http://www.digital-kaos.co.uk/forums...e-read-154246/
    Top Poster rrob311's Avatar
    I would check the schematic on what triggers the SRS light and I would pull the fuse if it has one for it or the relay.
    check your soldering ,if your sure the logic is correct , also are you sure you have put the chip on the right way around ?
    Top Poster swat cat's Avatar
    Aug 2010
    Romania, Bucharest
    Quote Originally Posted by pat kinsella View Post
    what auto section.... they closed if for moust of all
