Hi friend.
I can give you the update for the 1255.
Please, give a call and I can do it to you using remote control, Team Viewer if you have it.
Regards,
Nuno
Hi friend.
Regards,
Nuno
Sorry for bringing this thread alive..
I got one from china, and it not working.. usb-to-serial.
I flashed .ept ft232Rl, but even when i put +12 and gnd to interface and use un_mpcprog_can_1251nokiller
it does not shows even power/battery status.
Glued all over, anybody knows is 68hc11 erased or just ept? or solution?
who can help me register MpcProg 1251 protected?
thx
mine is around 2.5 MB
Did anybody did this:
Edc16 u34 on bench with this CMD obd2?
Diagnostics on vcds works ok, k1, k2, can ok.
On CMD soft, battery ok, but its saying to connect k-line (its already connected), but it doesn't connect...
Maybe interface is not ok?
Phhh? :|
Ask Mr Wang
if you use CMD CAN clone its only CAN!!
if you use CMD EDC16 FLASHER clone its only K-line.
CAN on table is only possible with GAteway attached and KL15C ON.
I got the point, this is CMD CAN Flasher V1251 obd2 - so i guess only can line exists..
But anyway diag via can should work also, and its not.
Vagdashcan also doesn't work on bench.
ps. mr.wang is pussy
thanks cammy
Someone has written with CMD1251 CAN OBD a file BDM in CDTI EDC16 C9 +??
BR
If somebody has ept and eeprom files for EDC16 Flasher, it's also helpful, can't find on forum.
even though 2 legs from 8 are not bonded, a spider is a still spider (93c86)
looking also for CMD flasher k-line ept... anyone? i already have the can bus and working good.
It is that possible to make CMD 1251 CAN <--> USB to work on k-line ?
BR,
Carradio2001.
