Results 1 to 15 of 15
    Default acekard2i stuck on loading
    when i try to use my acekard2i loading keeps appearing, i got the latest firmware from mickydribble (thanks) but still no joy, the dsi is 1.2e version.
    Jul 2010
    Default Mr
    hi there,
    I am having issue with my box - the box usb 2. i have got loads of channels missing. can anyone help please.?
    cheers people.
    f45tgpc4r
    V.I.P. Member mickydibble's Avatar
    Nov 2008
    modsvilla
    Quote Originally Posted by f45tgpc4r View Post
    hi there,
    cheers people.
    f45tgpc4r
    wrong section this is nintendo ds?
    Nov 2008
    modsvilla
    Quote Originally Posted by colinsully View Post
    your cart is a (acekard 2i)?.your memory card is probably corrupt you will have to format and start a fresh back your games/saves up on your comp and download the original firmware for your card the initial folders you should have are * akmenu4.nds (file)
    * __ak2 (folder) then if working you can add moonshell etc..
    here is the firmware http://www.digital-kaos.co.uk/forums...-ak2-ak2i-965/
    Quote Originally Posted by mickydibble View Post
    here is the firmware Digital Kaos - Downloads - ACEKARD firmware for ak2,and ak2i
    just cleared the memory card, then added the inital folders you gave me thre, will i add the dowload you gave me earlier?
    Nov 2008
    modsvilla
    you have to format the mem card then add the extracted files,should be 2 like i said,now put a game on to make sure it works and it isnt a cartridge problem!!!!.... then we`ll get to the rest....m
    loading sill appears, unzipped ak2_418_ and akaio1.6rc1 put their contents onto the memory card, added a game. i think its getting the better of me
    Nov 2008
    modsvilla
    format card again and just put the unzipped ak2_418_ on there should be 2 files - 1 file/1 folder...then put game on see if that works with a game first .before putting the akaio on. m
    still loading,
    when you say format card, does that mean put the unzipped info onto the card, just in case i'm missing something
    Nov 2008
    modsvilla
    still loading,
    no you have to right click on mem card (removable disc) and click format,then put the first files on card ,then a game...then check see if works
  11. #11
    did the format, added the extracted files from ak2_418_ and added a game. still loading
    sorry for taking so much of your time btw
  12. #12
    Nov 2008
    modsvilla
    its ok extract the attachment its the loader,if this doesnt work sounds like your cartridge as had its day m8 ...thnx micky
  13. #13
    he went on holidays friday night, ill try when he is back with the DSI,
  14. #14
    finally got to try this out, and wasnt able to extract the files said it was corrupt
  15. #15
    V.I.P. Member barrowmanandrew's Avatar
    Nov 2009
    scotland
    download firmware from here m8
