Results 1 to 12 of 12
    Default Dreambox DM500S Black Screen!!! :(
    Hi there everyone i was just watching a channel on my dreambox dm500s when the box completley froze. so i turned it off from the back and turned it back on and now all i get is a black screen, the standby light is green? someone please help me fix this thanks
    V.I.P. Member opsmonkey's Avatar
    Nov 2008
    var/etc
    hi mate.. i had this when i returned home tonight.. dead easy fix..
    unplug box from wall and remove all cables, SCART, Ethernet, Audio etc.. Connect Null Modem cable, run DreamUP on your PC / Laptop then go through the process of flashing an Erase.img (zipped file below).. takes about 13 minutes, then re-flash your backup.img ( i take it you made one..??)
    If you dont have a backup.img then you will need to re-flash an image like Gemini 4.2 or Pli..
    That will fix it
    ok mate i will give it a try thanks for your speed reply btw
    Thanks opsmonkey worked a treat
    I have the same problem.
    I tried to flash my dm 500s with pli-jade using flash wizard but it stacked on 84%.so i close it and restart but now doesn't detect the box.I tried to flash using dreamup and the following msg comes:
    "connection prepared,now switch on the dreambox!"
    I switch on the box
    "upload complete,waiting for acknowledge.."
    then after a while another msg comes
    "Box does not answer,attach aborted!"
    Fro here I cant do any thing.
    Pls help on that!
    many thx
    DK Veteran dank76's Avatar
    Nov 2008
    I can't get in the work where do u put erase on dream up??
    Dec 2011
    Arrow only getting fta channels
    i had to reflash my dreambox after someone factory reset mine now i only get fta channels dont get any other been at it all week its its open-pli with mgcamd thnx if you can help im climbing up the walls here
    Last edited by dundee64; 17th December, 2011 at 05:55 AM. Reason: never said model its a 500-s
    V.I.P. soft lad
    Mar 2008
    in a house
    you might need to contact the server provider,and get server details
    Jun 2012
    Default same problem
    i can upload some images but i can't other i will try the erase
    Have had the same problem, hopefully this will work.
    Nov 2012
    Default Dream box 500 flash
    Any advice on how i can flash my dreambox and how i can obtain all channels
    Aug 2013
    I also have problems with black screen on dm500s, hope this post will help
  13. The Following 2 Users Say Thank You to sticky1980 For This Useful Post:
