Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 59
  1. #16
    tehnosoftex's Avatar
    Romania
    Quote Originally Posted by rsibiza View Post
    Do you have original WinOls to work with evc BDM100,i have also Original EVC BDM100,but am unable to connect via cracked OLS,so i ahve to use BDMtoGO,but the files are locked to my Tuner,and i cant open the files.
    As i wont continue work with him,i have little troubles to edit maps,read out with my BDM,read,and write back,works well,but editing soft dont work?
    I manage to connect bdm 100 with cracked winols 1500 but only last week. Until now I use a older version of bdmtogo software which allow me to import in cracked ols. Last week a friend told me that if I will install last version of bdmtogo software and install the bdm drivers the winols will work with bdm 100 directly. And that is what I do and work 100%
  2. #17
    Oct 2008
    heaven
    Quote Originally Posted by carsolution View Post
    Hi guys.
    I am opening this thread because today I needed to use my BDM programmer and it didnt work.
    Allways the error "12v or communication error"
    Well it was damaged and I am here to share with you the solution.
    In the electronic board you will find 2 transistors, Q1 and Q2 at the front of the board.
    Q1 was damaged, replaced it and the BDM started to work again without any problems.
    The transistor has the reference J7Y.
    Hope this can help someone who has the BDM stopped because of this.
    Best Regards to all,
    Nuno
    you can use BC547 transistor
  3. #18
    Portugal
    You are giving the info or you are asking?
  4. #19
    Oct 2008
    heaven
    im giving the info when damage smd bdm100 transistors can replace bc547
  5. #20
    Top Poster Roma's Avatar
    UK
    If who needs .bin from 93?93 and motorola write my. I will lay out. ver 1255
  6. #21
    Portugal
    Already posted in another thread the Atmel and Motorola MCU entire read out for people who needs to program the device.
    Also inserted the update software to flash the BDM.
    Regards,
    Nuno
  7. #22
    Argentina
    Please. Could that thread?
    Thanks mate.
  8. #23
    Jun 2009
    I have this error. Is the solution in post one the right for me.
    Interface comunication error
    +12Vcc power error or Communication error
    And ist this the right connection for Bosch ECU and BDM 100 clone
  9. #24
    Jun 2009
    Now i have this errror
    Mpc family error x00000000
  10. #25
    Junior Member rentor61's Avatar
    italy
    hi do you sendme the pw please many tanks in advance
  11. #26
    I have that same problem. I change this resistor q1 and q2.
    I read eeprom maybe someone check?
  12. #27
    Jun 2009
    Have you try it on an other ECU
    My ECU was fault, this was the mistake by me
  13. #28
    Estonia
    Hi guys.
    Nuno
    Thanks for the useful tip. I had the "12v or communication error". Just to be sure I replaced all 3 transistors (BC547C) and the china clone BDM100 came alive again! :-).
    Got 4 of he transistors for 50 euro-cents from local electronic parts store.
    Thanks.
  14. #29
    Hi do you know if one or both are npn or pnp types
    i/e what did you replace with?
    good work Regards John
  15. #30
    Default Have you try
    Have you try
  16. The Following 4 Users Say Thank You to maciej For This Useful Post:
    carcode (21st May, 2021), kaziukas1958 (15th August, 2022), mexanico1971 (2nd September, 2017), scoot (22nd May, 2014)
