How to load software to 9600IP
Firstly you will need the following tools:-
PC running Windows, which has an available serial (COM) port. If it does not have a COM port, you will need a USB to serial adapter
Null modem cable (also known as a crossover cable), with 9 pin D-connectors on end (female)
Download the following from the Downloadcenter:-
Click Here
Uploader v13
Bootloader 1.34
Software BorisT53
Please note: If your receiver is already flashed you don't need install those files. All you need to do is a internet connection and you are ready to go.
To open the files, you will need to have Winzip on the PC to extract the achived files. Make sure you extract all the files to a known folder, before starting.
Load bootloader on to receiver
Run UploaderV13.exe
Select the available COM port by clicking on COM1 (if this is not the COM port to be used).
Select Boot option, by click in on Main (this toggles between Main and Boot)
Click on Open File, and select the bootloader bin file
Click on Start Down
Click on OK on screen
Press OK on receiver
Press standby ***8211; the receiver will boot and the file will start transferring to the receiver
WAIT! - click OK on loader screen when told that transfer is complete
Press Exit on screen
Software is updated
Load software on to receiver - NOTE you can also use webloader for this function (read below)
Run UploaderV13.exe again, and select the COM port to use
This time, make sure that Main is selected, and not boot
Click on Open File, and select the software bin file
Click on Start Down
Software is updated
To load channel list - NOTE you can also use webloader for this function (read below)
Run Uploader
Click on ***8220;Open File***8221;
Choose channel list file
Press Open
Click on ***8220;Start Down***8221;
Channel list is updated
Once you have upgraded the s/w. Connect the antenna connection, and go into Menu, Installations to set up the antenna.
Set up Diseqc motor
Press Menu on the remote
Installation
Antenna Setting
Satellite - Choose satellite (press OK)
Changed Disqec1.2 to ON
Select Diseqc1.2 settings
Used left and right to move dish East / West for max signal / quality
Select Store Position - press OK
Press Exit
Job done
Follow same process for other satellites
If you have loaded the channel list from the Downloads / Settings section, you should have channels already loaded. If you want to choose pre-sorted channels, select FAV on the remote control.
Webloader
Once the bootloader is on the receiver, loading of software, keyfiles and channel lists can be achieved using the webloader function. You don't need any software for this, just open a browser on a PC on the same LAN as the receiver (IE, Firefox, Opera, Chrome, etc), and enter the IP address of the receiver, i.e. 192.160.1.6
This will then ask for a username and password. The default username is admin, and the default password is 0000. Once these have been entered, you can browse to the files you want to upload, and then send them to the receiver via your LAN
You can use Webloader to load software, keyfiles or channel lists, but not bootloader (which needs to be added via Uploader V13
Once the files has been uploaded to the receiver, please wait while it automatically reboots
More info at>>>>>> NanoXX Support Forum • Index page
