WRONG ZBC FILE
clone tem problema de tokens, chines nao consegue resolver.
WRONG ZBC FILE
great job from GOPELHU
no one could help him for this hard word?
there is a software that i use for this cases it support microprosessors and eemproms and also it connects to real word with usb emulator and serial too.
you can make all the circuit inside this software and see the result if iea software could find the hadware .
the software is called proteus from labcenter. google it
it may has your solution to cryptografic memories 1 wire
do you haVE THE FIRMWARES FROM ATMEGAS TO LOAD IT TO PROGRAM TO MAKE A CHECK?AND THE DATA FROM THIS CRYPTOGRAFIC MEMORY TO load IT TO other types of memories of this kind to bypass the security......?
always believe that programing procedure is far away from pratical use
reading of the DS2432, correct??.
where is located the 24C16?
Turks are the property of the original construction machinery in china, this address is received from a machine you know Zed-BULL Haber Portal?
this link can help someone to understand how this memory ds2432 can talk to hyperterminal
http://www.xilinx.com/products/board...aze_ds2432.pdf
in this memory are the tokens of zed bull?
new information for find key in ds2432
http://www.xilinx.com/support/docume...es/xapp780.pdf
as you can see the eeprom has a key that is known only to designer . the esy part is that atmega2561 send the data to eeprom to be hasp with this key and the response of data goes to atmega2561 .microcontroller compare this data with the hasp and the same key data,
soes anyone can send the asm version of microcontroller to find the secret data key and program test this key with programing new ds2432 to have a full working zed bull?
someone with good knowlegde of assembly and the source code of atmega2561 can relock the device protection
source code of megas or hex codes for avr studio?to send
here is a book to hack this kind of memories and other electronic enquinment
http://www.grandideastudio.com/wp-co...proof_ch14.pdf
those information i believe are enough to clone as a original copy the zed bull
download zed bull new version 7.2.2
Hickleys :: The Zed-Bull Transponder Machine - Downloads
joe06 (26th March, 2018)
Hello.
I have a zed bull clone v.5.0 europe
after power on I get :
DS ERROR !..
Error code: 4
any ideea ...
there are two kinds of Zed-Bull clone in the market.one is with power adapter only, the other goes with both the power adapter and OBD2 cable.
hi all been following this thread
got myself a clone zedbull
very happy with it
had a jma tpx clone machine plugged it in and it does tex4d to tpx2 chips no problem
forgot to post link of modual
NW Keys Ltd - JMA TRS5000 TPX upgrade module
