Here you go guys, but no one can tell me may I update my zed bull with any ZBC file, because I saw that some zbc have serial number, which is not like my zed bull...can I make problem if update with zbc which contain different serial number?
I have a mini zed bull with software 5.08 below. He wrote my card 0 tokens will DS2432 chip but I bought one and want to ask someone if dump files for him to share them and also how I can Fix problem 0 tokens also began to give the device is not recognized as a disconnect and connect with usb cable is displayed on the port and it is turned on and connect it gives device is not connected
I bought chips from this picture 3.4 and 5 and soldered them on my but I need to dump DS chip
better to buy full size zedbull
better board
I want repair my mini zed bull help me please
joe06 (23rd March, 2018), jorgesecurity (30th October, 2024), satoniboy (7th March, 2021)
..and unless you can edit the Atmega EEPROM, then your out of luck.
I have atmega chip and it is no token limit if added ds chip dump where he shared his colleague will be there in atmega chips recorded a serial number and ds chip in another record
I believe the DS chip is a SECURE memory chip with the serial hard coded into the chip. So you aren't going to get the contents of the chip or be able to change the serial number of it!
You either need to use the original chip and get update files from a Chinese seller to get the tokens or buy another unit.
gopelhu (17th January, 2016)
How do I know whether mini zed bull with counter and limit tokens?
Can my serial number of mini zed bull be converted DS dump file to be with him sense to remodel your ds dump file with my serial number?
Does any one know the M dongle wiring????
I have Zed Bull and Error code: 3
Have any solution?
BR
Greetings, dug up an old topic, but maybe someone else is interesting.
I was able to read eeprom closed atmega2561 zed bull.
It was possible to read through the game with a supply voltage, reducing , and at some point atmega surrendered, but only got to read eeprom area, flash is not given, but I think that,if managed eeprom, ie the ability to read flash ... and maybe someone out, I only gave direction ...
eeprom attach a file, maybe someone will be interesting to look at,
EEP_B38DFBAB47470031.rar
anonbeat (8th June, 2019), gaston37 (16th June, 2020), gopelhu (31st December, 2017), paul_12345 (3rd December, 2016)
Please say which chinese seller is recommend these days to buy zed bull big size?
Can someone please upload Zed-Bull Unlimited Token from post #414 ?
