Can Ford chips be cloned by ZedBull ? .. I've learned how to do the remotes but the chip is still a problem for me
wbr
I'm not update zed-bull, not work sina prog
avrdude -C avrdude.conf -c usbasp -p m16 -q
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
It's possible isp on board it not good?
wbr
Don't confuse "Standing on my Shoulders" with "Treading on my Toes" ..
Can someone help me with link for good Zedbull from Aliexpress
I bought from this seller:
https://www.aliexpress.com/item/3291...27424c4dFWf7Ko
If it's normal that the buttons on it do not do anything, but it seems to work fine by USB using EFFl software, then it's good.
Zed-Bull Mini-China 100% working, reading personally the processor was open.
downloaded 145 a thank you said three
hola mini zed bull de 1 dia al otro 0 tokens de 500 a cero help please
Hello everyone I bought a zed bull mini clone but alas the software is unusable a load of copied & pasted software from all over the place, has anyone a software pakage that will load and work without faffing about many thanks in advance ,Baz
You must install once the setup V5.06.
The setup is the only required process you must do to get the final 5.08.
There ist no installation which goes directly to it.
A zipped version will not work because the setup must be once registered in the Operation System.
The next ist to copy the whole folder of 5.08 over the Installation an now you are ready to go.
There are many videos on Youtube.
As far as i know the chinese allready gave you a pdf with illustrations how to do this.
Thats realy not difficult. Approximately 5 minutes for installation.
An update can be done with a ZBT file only if the ZBT file is for the same serial number of the device we want to upgrade
Question for "SEREGKA"
For which programmer is the compatible adapter for atmega QFP64 to DIP 40?
for anyone
First post!
Can someone please help decode the info in the picture, how do I copy this chip?
Should I buy a 4D 67 and try to programme the chip in the car?
Can the zee bull clone copy this chip?
Hi SEREGKA
Thanks for the pictures!
I tried to connect the atmega to the board itself via all ports (JTAG and serial to BEEprog,ICSP to usb asp programmer to SINAProg without success.
Atmega is completely locked, I can't even read the ID of the chip.
Is it with the adapter qfp64 to dip40 that you are here to read and program the atmega in the ZIF socket on the beeprog?
The zif socket should work with ports for parallel programming.
It may make sense to try resetting the lock bits with an AVR doctor!
After spending all yesterday and last night trying to install the hacked software, I reckon these zed bull things are one big scam.
They can read chips and that is about it.
Whoever gave it the name zed bull was having a laugh because that's what they are BULL!
