Page 39 of 44 FirstFirst ... 293435363738394041424344 LastLast
Results 571 to 585 of 651
  1. #571
    mikajna's Avatar
    Mar 2015
    Default ZBC Files Upload
    Here you go guys, but no one can tell me may I update my zed bull with any ZBC file, because I saw that some zbc have serial number, which is not like my zed bull...can I make problem if update with zbc which contain different serial number?
  2. The Following 2 Users Say Thank You to mikajna For This Useful Post:
    asensi (17th March, 2022), BallJoint (9th December, 2015)
  3. #572
    Sep 2015
    Default help please
    I have a mini zed bull with software 5.08 below. He wrote my card 0 tokens will DS2432 chip but I bought one and want to ask someone if dump files for him to share them and also how I can Fix problem 0 tokens also began to give the device is not recognized as a disconnect and connect with usb cable is displayed on the port and it is turned on and connect it gives device is not connected
    I bought chips from this picture 3.4 and 5 and soldered them on my but I need to dump DS chip
  4. #573
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    better to buy full size zedbull
    better board
  5. #574
    Sep 2015
    I want repair my mini zed bull help me please
  6. #575
    gopelhu's Avatar
    Jan 2010
    EU
    Quote Originally Posted by ivaylomezdra View Post
    here are two zb ds2432 dumps, but you will see that are them cannot has a 8 bytes hasp in dumps.
    regards, G
  7. The Following 3 Users Say Thank You to gopelhu For This Useful Post:
    joe06 (23rd March, 2018), jorgesecurity (30th October, 2024), satoniboy (7th March, 2021)
  8. #576
    Apr 2010
    ..and unless you can edit the Atmega EEPROM, then your out of luck.
  9. #577
    Sep 2015
    I have atmega chip and it is no token limit if added ds chip dump where he shared his colleague will be there in atmega chips recorded a serial number and ds chip in another record
  10. #578
    Jan 2010
    I believe the DS chip is a SECURE memory chip with the serial hard coded into the chip. So you aren't going to get the contents of the chip or be able to change the serial number of it!
    You either need to use the original chip and get update files from a Chinese seller to get the tokens or buy another unit.
  11. The Following User Says Thank You to paul_12345 For This Useful Post:
    gopelhu (17th January, 2016)
  12. #579
    Sep 2015
    How do I know whether mini zed bull with counter and limit tokens?
  13. #580
    Sep 2015
    Can my serial number of mini zed bull be converted DS dump file to be with him sense to remodel your ds dump file with my serial number?
  14. #581
    Mar 2016
    Does any one know the M dongle wiring????
  15. #582
    EU
    Hello,
    I have Zed Bull and Error code: 3
    Have any solution?
    BR
  16. #583
    Dec 2016
    Greetings, dug up an old topic, but maybe someone else is interesting.
    I was able to read eeprom closed atmega2561 zed bull.
    It was possible to read through the game with a supply voltage, reducing , and at some point atmega surrendered, but only got to read eeprom area, flash is not given, but I think that,if managed eeprom, ie the ability to read flash ... and maybe someone out, I only gave direction ...
    eeprom attach a file, maybe someone will be interesting to look at,
    EEP_B38DFBAB47470031.rar
  17. The Following 4 Users Say Thank You to toha For This Useful Post:
    anonbeat (8th June, 2019), gaston37 (16th June, 2020), gopelhu (31st December, 2017), paul_12345 (3rd December, 2016)
  18. #584
    Jun 2010
    Please say which chinese seller is recommend these days to buy zed bull big size?
  19. #585
    Aug 2010
    Can someone please upload Zed-Bull Unlimited Token from post #414 ?
