SIS DOES NOT ACTIVATE WITH ET YOU HAVE TO GET SEPERATE ACTIVATION FOR IT NOT SURE IT THERE IS A KG FOR 2010B YET HAVE A GOOD ONE
2010B Cat ET presentation
Yes you'll get the previous license but the previous feature(WinFlash) is death.I faced ths problem Bro when i was upgrading it in windows 7 X86,now i'm downgrading it to ver 2010A,coz no solution so far.Hopefull SomeOne wish to post the solution as soon as possible.
Thank All.
Anyone know is the function of the connector that I'm hanging in one of these photos ? I find this harness in my work, and it seems be to connect a ecm without the truck harness, but I don't know what purpose has that connector.
ImageShack Album - 4 images
Can be a connector to a power supply to not use the battery wires ?
hello
PLZ any can help me , I need ET 2010B keygenerator
thnks
There is not a keygen for et 2010b yet (that I know of) and asking for one is a no-no.If your absolutly need 2010b uninstall 2010b install 2010a licence it ( post pcid and some one will help you with key) and install 2010b as up grade it will keep the 2010a licence.
A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
THAT PICTURE LOOKS LIKE THE CAT BYPASS ENGINE HARNESS FOR DIRECT CONNECTION TO THE ECM UNDER THE HOOD YOU CAN MAKE ONE FOR @$75 WITH THE 70 PIN CONNECTER IF YOU WANT THE PART NUMBER JUST LET ME KNOW AND I WILL POST IT FOR YOU ALSO CAT WILL CHARGE YOU @$450 FOR THE BYPASS HARNESS IF YOU BUY IT FROM THEM THE 70 PIN PLUG ALL YOU NEED IS TO BUY PINS AND THE TWO PLUGS 9 PIN DEUTSCH AND 70 PIN , YOU ALSO NEED A SWITCH TO TURN THE POWER ON AND OFF AND ALLIGATOR CLIPS TO TAKE POWER FROM THE STARTER ONCE YOU HAVE ALL THE STUFF YOU CAN WIRE IT IN ABOUT AN HOUR
The connector that I want to mean is this :
Uploaded with ImageShack.us
I know that it's a cable to connect a ecm without the engine harness. Can be that connector to connect a swith dieselman ?
I see that the grey connector of the harness isn't the same that the grey connector of my diagnostic interface, I might that i need a adapter how this :
85111614 - 85111614 9-Pin to 6-Pin Adapter
It's correct friends ?
hi,,
whem i try to open the winflash, i recibed some message "No licence", but i have the some licence for 2010a, what its the problem?
