Did you try Ebay to buy it? It will work with the engines you want to test, if it has a 6 OR 9 PIN connector you can work with it with the right soft. Do a search for the soft you'll find it. hope this helps.
I am looking at the Nexiq interface now after the posts here can anyone recommend a good place and price to buy one ? any anyone any able post some of the software they are using with theses interfaces ?
i am hoping to use it on cummins Detroit and cat engines as well as ABS for trucks feedback would be handy many thanks
thanks mate
This is a bit older thread, but did you find one? We use the Nexiq USB Link in our shop, and it works with everything but CAT.
WWW.TOOLTOPIA.COM THEY WERE THE CHEAPEST PRICE I GOT THE NEXIQ 125032 WITH THE 6 & 9 PIN FOR $685 WITH 3 YEAR WARRANTY YOU CAN BUY OTHER ONES BUT THIS ONE WORKS WITH EVERYTHING I HAVE TRIED YET MACK, CUMMINS, DETROIT, ECT AND NO PROBLEMS I WOULD NOT RECOMMEND BUYING USED ONE BECAUSE PEOPLE ONLY SELL THEM WHEN THEY HAVE PROBLEMS WITH THEM HAVE A GOOD ONE
The place I work at is direct with Nexiq, and $685 is a very good price. I think dealer cost is around $650 or so... Thin margins for them.
LOOK ONLINE I EVEN GOT FREE SHIPPING IN THE US SO I GOT A REALLY GOOD DEAL ON IT
look this
SU Enterprise : Home
The IC4 works with all the soft, I personally have used it with cat, int, dddl,cummins, allison, wabco, bendix. A lot of soft dont list the IC4 just use it under usb/ rp1210a compliant.Hope this helps.
A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
usb link works with most software cat,cummins,detroit mack,allison,wabco, isuzu,hino,volvo,you name it it works also not just 6&9 pin get an obd II connector and tie into isuzu and other gm products works great
For programing I have not tried it, for standard data works great(usb is faster than blue tooth), It does not do duel data with cat but still works great. And the price is nice too, orderd it and it was there the next day. There customer support is a little crappy thou, and it needs to be licenced like software, so there are a couple of downfalls. But i like it, I guess it is your own preferance. And it is the only one you can use with the Int. Service Asst soft. Hope this helps.
www.mile-x.com/pro-link-125032-usb-link.aspx
does this work with john deere service advisor?
