Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 50
  1. #16
    GABI_D can you also make EGR off for Peugeot 2.2 HDI EDC15C2 ecu?
  2. #17
    nicowico, if you can read ecu dump is not so hard! open ecm2001, select corect driver, select your file and go to injections - phase of injection in ecm2001 is EGR, like in picture from coolins is reprezent in 3d grafic, put all value to hi and all is done! of course you can open your file in winols and make modify, but winols is for real profi. need more time for study how to work etc.
  3. #18
    any way if you have dump from ecu post hier ori file. what you expect to this modify? EGR off.
  4. #19
    OK, here it is,
  5. #20
    what model of peugeot? 406 2.2 hdi?
  6. #21
    hier is file mod whit EGR off.
  7. #22
    file is corrupted.
  8. #23
    pawliukazz's Avatar
    Jupiter
    Quote Originally Posted by Nicowico View Post
    file is corrupted.
    No. It just needs to be renamed ftom ".mod" to ".bin" I just did it for you
  9. #24
    Unhappy
    It's a complete other file than I uploaded
  10. #25
    pawliukazz's Avatar
    Jupiter
    No m8, this is a good file. It suppose to have more differs than few bytes, it's ok. I mean it's not a few bytes which you can disable but you have to rewrite all ecu's program.
  11. #26
    Thumbs down
    This is my file:
    FILE: Fap removed
    Bytes: 7FFFF
    Checksum: 417C
    Marca: Bosch
    Num. HW: 0281010773
    Num. SW: 1037353575
    and this is the other file:
    FILE: nicowico egr off.rar
    Bytes: 286B0
    Checksum: C43C
    Marca: GM DELCO
    Num. HW: 19N?)?Z??+ ?
    Num. SW: D9?_"?Z????`
    It's a General Motors file.
  12. #27
    pawliukazz's Avatar
    Jupiter
    This is my file:
    FILE: Fap removed
    Bytes: 7FFFF
    Checksum: 417C
    Marca: Bosch
    Num. HW: 0281010773
    Num. SW: 1037353575
    Bytes: 286B0
    Checksum: C43C
    Marca: GM DELCO
    Num. HW: 19N?)?Zš?+ ?
    I'm saying to you - use file which i renamed! i had the simmi9lar problem because gabi_d uploaded a zip archive which is not good i changed to rar archive now should be ok! trust me, the file is good you just extraxt it not correctly
    YOU FIRSTLY HAVE TO EXTRAXT the bin file out of the archive! only then you can use it normally! if you don't know how to do it - use google and find WinRar
  13. #28
    nicowico, sory for problem, but i dont find any error in file! you must to extract file, unpack file from zip or rar in mod or bin or unnamed! you have galletto or kwp2000? in any case you can upload file unnamed, bin or mod, etc.
  14. #29
    Ok, you were both right. My mistake. Sorry.
    But..... It does not work. Got a polution fault right after I started the car and the car went in limp mode.
    Reflashed with the ori file. Pitty.
  15. #30
    Hi Sir
    Would you cut off EGR for me please? Can you do this?
    It is a Mercedes C200 CDI
    Thank you very much.
    Quote Originally Posted by gabi_d View Post
