Protect opening on PC or reading protect from ECU?
protect to open again in Winols
I read manual and i see it's possible but i can understand how to works.
regards
joshuac
Why would you do that?
They only way to protect your files is on ME7 or EDC15.
You can use a protection board and nobody can't read it.
For later ECU, there is no real protection. You can always use a BDM to retrive the data (of course if the BDM pads are still there.... But you will also lock yourself out.
From who? It doesn't make sense!
1. If you need to protect your files, you can archive it with some tool like WinZip, WinRAR, 7-Zip etc... and put password on archive.
2. If you want to sell you file, but don't want to someone other use it, that someone must be in some master/slave relationship with you.
But, in the end, there is no protection against old fashion reading...
ok i explain the sense of my question.
I buy one file an chiptunner, then i put on the car and all works very very fine. Then i try to see the file with WinOls, but i have one error:
"This software version cannot be processed, since it is already modified"
Some guys tell me this file is protect for not read with WinOls. Now i try to understand how this protect works...
In ECM2001 i can see the maps....
regards
joshuac
I'm not sure how they do that, but I had similar situation. The conclusion was: You can put few bytes in some free space (if exist ofc), which is out of check-sum and that should be indicators, is something modified or not. If program finds that bytes in file, it refuses to open it. I believe, same thing is with WinOLS. But, that is only protection for WinOLS.
yes i too think its only bites, and when you open, WinOls reads that bites and open or not.
This is reason for understand the protection
I try to simulate with WinOls this situation but without success...
Because than i will go to compare original and protect,....
Someone can do more ideas???
Someone knows how to protect in WinOls??
regards
joshuac
Can you upload one of those files?
Here is a tool for unlocking this files. It requires .NET 2.0 to run...
LICENSE:
1. This software is freeware and can be freely shared.
2. Selling this software, in any kind, is prohibited.
3. This software is provided "AS IS", use it at Your own risk.
If You agree with above terms, you can use this software.
Note. If sw say protection V1 or V2, you are sure about unlocking. If say V3, he will try to remove protection, but I'm not sure about results... It may work, it may not.
darka7 (26th January, 2020), haidumartocian (3rd April, 2019), Kalchev (5th April, 2020)
the protection u are on about isnt really protection
what it is is the file was modified in winols and the tab insert spi tag was ticked.
this stops winols rereading the file
all it does is insert evc.evc into the file
u can then open the file in any hexediter software and replace the evc.evc with ff's
then it will open in winols (it will ask u to correct the checksum)
hope this helps
asfore the older files that use an encryption board these can be read too but u need a program that unencrypts the files.
Nop. This is about NOREAD problem. And also, there is few version how can it be written into file.
noread = byteshooter
cmd.cmd = cmd flash
evc.evc = evc/superchips spi and winols sw
if u open the file that winols cant reread in hexeditor software ie hex workshop u will see the tags that either winols puts in or other people put in
