Results 1 to 5 of 5
    Default Increasing tv channels
    Hi quick question...
    I have two boxes on standard and one eurovox if i increase the tv packages to the max will i be able to see those channel on my eurovox in the other room in the house?
    badapple's Avatar
    REQUEST
    Hi m8, NO it dosent work like that. Even with the minimum package you should be able to pick up ALL channels on the eurovox. Just try a clear data/factory reset and re-scan using the correct SR.
    By the way, if your area is on nag3, then youw will slowly loose channels and there is no fix.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    yea I have just had N3 so i was going to increase the packages channels so i could watch them downstairs with the VM package and upstairs with the eurovox. Will that not work then?
    Mar 2009
    no the eurovox will not work on nag three.there is a way but not allowed to talk about it on this site. look through thr post in the starview section on this site starview 6 combo lan is the way to go.
    Jan 2009
    its not the way to go as it keeps going down save your money and wait for a while starview 6 always going down
