Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Mar 2010
    west midlands
    if the vehicle starts with brake cleaner then you will know the timing is in synch & it will be down to fuelling trouble. you need to oscilloscope test the cam & crank sensor signals at the ecu pins for good waveforms to make sure it's not wiring trouble
  2. #17
    Nov 2009
    Portugal
    Take a look at the ECU, it is located behind the whell and in that space it takes a lot of water.
    Open it and see if you have water signals.
    Remove the injectors connectors and see in the connectors if you have signal to open the injectors.
    You can check it with a led, The supply for the injectors comes directly from the ECU, if you dont have signal start considering you can have ECU damaged.
    Regards,
    Nuno
  3. #18
    Nov 2009
    Portugal
    I forgot to say that at front of left wheel there are a big earth point, check it for bad contact, it is not the first time this problem happens to me.
    Regards,
    Nuno
  4. #19
    Jun 2010
    Default engine number...
    thanks for your help again...
    here is the engine number z17dth 01521093
    hope this might help some more!!
  5. #20
    Jun 2010
    Default cheers...
    Quote Originally Posted by carsolution View Post
    Regards,
    Nuno
    nice one thanks for the advice will check them tommorow..
    im loosing patience with it!!
  6. #21
    Jun 2010
    Default hi...
    Quote Originally Posted by dafdiagnos View Post
    cheers for that but have checked all wiring and is fine i still need to do the brake cleaner test!!
    its driving me mad....think im gonna have to check receptor ring aswell although i would of thought it would be pretty unlikely?!
    cheers
  7. #22
    Jun 2010
    Default hi mate
    Quote Originally Posted by racin-snake View Post
    engine code should be in service book and on the engine too
    the ecu is at th top of the engine the edu is at the back of the engine at o/s drive shaft or there about's
    if you can give year ect it will help us to help you
    and brake cleaner will start this car if sprayed down the inlet manifold
    but only briefly as long term may cause damage
    post full details
    remember we cannot help with no info
    as we cannot see the car and diagnostics is one thing but doing it remotely is another
    post full details no need for vin or reg
    just engine year ect
    i have put this in my thread but here is my engine numbers z17dth 01521093 hope this helps !!will do brake cleaner test tommorow and let u know the outcome!! thanks for your help man i need it!!
  8. #23
    Jun 2010
    Default update...
    have tried the brake cleaner and it will not start...any more ideas other than burn it!!
  9. #24
    obdmaster's Avatar
    Never never land
    Wink Engine mechanically wrong?
    Quote Originally Posted by westy_77 View Post
    If it dont run on brake cleaner m8, your engine is mechanically wrong, id of thought!!!!!
    I stand to be corrected?
    You need every tool in the book, to do this auto locksmith job.
  10. #25
    Meat-Head's Avatar
    Quote Originally Posted by obdmaster View Post
    agree, but
    a) racing-snake (think) always uses it
    M-H-M prefer 'Easy Start' - causes more damage and smells nicer
    b) try towing in gear 1/4 mile then brake cleaner to 'warm' up the engine
    acts like an air compresser
  11. #26
    DK Veteran teuton's Avatar
    Nov 2009
    Mexico
    check compression, do a leak downtest!!
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
  12. #27
    Jun 2010
    Default easy start ...still wont start!!
    hi have put easy start in and still wont start what could this be...
  13. #28
    Meat-Head's Avatar
    Your engine is ~~~~ed, you need a new one.
    remember to inhale that Easystart, good stuff
