Results 1 to 15 of 19
    Default CD30, CD70, DVD90 ...
    Hi @ all,
    at first I am sorry for my bad english.
    Can somebody tell me if I can make a CD30, CD70 or DVD90 ... work in another car when it was not diverced by programming from the old car where the radio was inside? If it is possible please tell me how.
    Thanks.
    alexics's Avatar
    Kidderminster
    Quote Originally Posted by C4R View Post
    Hi @ all,
    Thanks.
    You have to unmarry from the original car and put it into delivery mode. A Tech II or similar will need to be used to marry it back up to the new vehicle. If the display is not programmed to the set you will get 'display safe' and nothing else.
    Thanks for your answer. But that is what I know by myself.
    My question is, if it is possible to put the radio into a new car when it was not "unmarried" and put into delivery mode, for example because the car had an accident.
    Please help!!!
    M1DJF's Avatar
    West Yorkshire
    Yes the radio has to be in delivery mode(unmarried) and than it has to be configured to the new car with TECH 2 TOOL .
    Please help!!!
    I don't know if it is because of my bad english, but your answers are not really want I want to know.
    I know that a radio in delivery mode could be married with tech2 to the car.
    My question is: How can I put a radio into delivery mode even if the car where it is from is broken because of an accident?
    Thanks for answers.
    alexics's Avatar
    Kidderminster
    Thanks for answers.
    The car itself is irrelevant. It is the radio that is put into delivery mode and can be removed from the vehicle whilst this is done. You do not need it in the vehicle in order to perform this operation. As long as you have the right equipment.
    Oh, that's a really good answer. Thanks you very much!!!
    But please tell me what I need to put it into delivery mode.
    alexics's Avatar
    Kidderminster
    Take a dump from the eeprom and I will help you.
    MONTPELLIER-FRANCE
    Is it possible to have eeprom dump of a CD70 unregistered? Thanks.
    Quote Originally Posted by seb34 View Post
    Just use opcom or tech2 then try to read the VIN from the Unmaried CD70 then go to the dealer ann ask them to give you the car pass ( code ).
    Then you put CD70 in delivery mode by resetting it
    Then install it in your car and marry it
    Quote Originally Posted by haussys View Post
    The VIN isn't stored in the CD70, it's in the CID display. If you don't have the matched display you can't get the code.
    Hi guys,
    I need to know, in cd70 there are two eeproms which one I have to remove in order to make a dump?
    Cheers
  13. #13
    MONTPELLIER-FRANCE
    Default cd 70 registered
    Quote Originally Posted by alexics View Post
    Here is my dump for a 24C64 eeprom
    Thanks.
  14. #14
    Thanks.
    This is a astra CD70?
  15. #15
    MONTPELLIER-FRANCE
    Quote Originally Posted by yysnet View Post
    It's a vectra front panel but was installed in astra.
