Do you want to find out the ip address of the router or the ip address of a dreambox that's connected to the router?
EDIT:
If you open a command prompt and past in the following, it should generate a file in c: which will tell you all devices and the ip addresses on your network.
The router ip address is 192.168.1.1Code:FOR /L %i IN (1,1,254) DO ping -a -n 1 192.168.1%i | FIND /i "Reply">>c:\ipaddresses.txt
