It sounds like Nagra 3 is creeping into your box slowly but surely Seriously tho m8 i was gonna say check your connections but you alreay have so maybe the tuner is on the way out.
hello all
my dbox2 is all good apart from the fact that recently in the last month or so when i zap to a channel its making some weird noises that i cant explain in words and im not getting a picture,,,on another day its fine but another channel might be doing the same,,today while trying to watch itv 4 it was playing up i checked my cables etc and all seems fine,,,any suggestions ???
thankyou for taking the time to read
The control of information is the consolidation of power
?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
IF I HELPED HIT THE THANKS BUTTON
thats what i was thinking but i had these weird noises before and it was dodgy cable connections but as i said previously i checked them and all seems fine my snr readings are as follows max 57825 and min 52942 does that sound like a good signal ?
Yea your SNR seems ok. If you have any splitters in m8 take them out and see if that helps.
Save you r service and bowk s
And try a rescan,they may have moved a bit
Try a slow scan,If no better FTP your service and bows back..........Paul
PAUL
ok will give that a go this evening and hopefully it might rectify it
thanks for the advice
you want to try to get 55k or above, preferably above 60k. below 55k u can get picture pixalating and the chirping sound.....try a booster and or gently move the aerial connection on a prob channel and see if u can get snr above 55k, mines a little loose and needs to be adjusted from time to time.
cheers
unplugged the splitter and hey presto,,no more funny noises and squeels and blank screens,i would never have thought to do that in the first place,,,thanks for the help
